4wd front driveshaft angle >
Old 09-11-2023, 01:52 AM
lexusbest's Avatar
Default 4wd front driveshaft angle
Asking here because I don't see any solid reference to this topic.
I like to compare car geometries between brands and saw a noticeable difference in the front driveshaft sweep. I see front driveshafts are usually swept backwards while rear driveshafts are swept frontwards.
There are some brands with the front driveshafts close to being straight and others with a lot more backwards angle.
Do you know guys how does the front driveshaft angle affect to the cars behaviour? How do the forces apply?
lexusbest is offline
Old 09-11-2023, 03:46 AM
sosidge's Avatar
I'm sure the theoreticians will say that the swept-back front driveshafts will give better bite under braking.
But in reality I expect it is all to do with packaging. There is limited space in a modern 4wd chassis layout. You may need to move the front gearbox around to get the weight distribution/wheelbase/steering geometry you are looking for.
sosidge is offline
Old 09-11-2023, 10:47 PM
Trader Rating: 19 (100%+)
The effects of drive shaft angle
Here is one coverage on this topic.
Juglenaut is offline
