Old 04-25-2006, 06:25 AM   #1
Glowster21's Avatar
Trader Rating: 116 (100%+)
Default Torsen Center Diff Question
New to Nitro...what is the benefit/negative of using a center Torsen Diff? Why would you want to use it and what does it do for you? Any help would be awesome.
Thanks!
Glowster21 is offline   Reply With Quote
Old 04-25-2006, 07:27 AM   #2
The purpose of a torsen diff is very similar to that of a limited slip diff, it transfers more power to the loaded wheels rather than dumping it all on the unloaded wheels like a regular diff will do.
This helps with acceleration as the front end of the vehicle unweighs shifting the weight to the rear wheels the torsen keeps the power going to the rear whereas a normal diff would start sending it to the front. If you've seen pictures of RC cars with tires that looks like pizza cutters then that is what happens with a normal diff. Now this is a benefit on hard packed, high traction tracks or surfaces. On loose tracks or surfaces it will cause too much grip and make the handling feel loose and bouncey also causing strong on power understeer.
Bottom line is that if you have one try it out and see if it suits you and where you use it. If not then experiment with your normal diff by trying different weight of diff fluids and see what effect you get.
AreCee is offline   Reply With Quote
Old 04-25-2006, 11:46 AM   #3
Torsen Diffs are damn exspensive to... Just use good diff oils and find what you like.
Anyone here about that kyosho Diff Grease? it comes in 1000- 10000 Weights.
Chad_R40 is offline   Reply With Quote
Old 04-25-2006, 11:52 AM   #4
tmaxxking's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to tmaxxking
Default torsen diff
torsen diff most should see service every 4 hours of run time ..
who wants to pop a buggy apart every 4 hours of run time to clean and regrease a diff ......
FEEDBACK LINK
rctech.net/forum/showthread.php?t=106423
tmaxxking is offline   Reply With Quote
Old 04-25-2006, 03:48 PM   #5
You don't grease a torsen diff. It uses a special fluid. At least the OFNA torsen diffs do.
Old 04-25-2006, 05:00 PM   #6
Trader Rating: 20 (100%+)
So does Fioroni .
Brandon Powell is offline   Reply With Quote
Old 04-25-2006, 05:19 PM   #7
Trader Rating: 14 (100%+)
i fill my diffs with fresh fluid after everytime i race
o.s. power is offline   Reply With Quote
HIGH POWER ENGINE AND CENTER DIFF QUESTION !! dead1dave Nitro Off-Road 6 06-30-2008 07:31 AM
OFNA 9.5 Center Torsen Diff - Like New - $40 SoCalTazer R/C Items: For Sale/Trade 1 08-04-2006 04:44 PM
OFNA Torsen Center Diff brand new Hyper 7 cheap fatlong R/C Items: For Sale/Trade 8 06-03-2006 11:10 AM
center diff question Genius Electric Off-Road 6 08-10-2005 06:12 PM
Fioroni torsen diff center gear WTB sweetpea R/C Items: Wanted to Buy 0 09-21-2004 07:17 PM
