Affordable 1/10th RTR-Kit for spec racing
Hi guys,
I have a group of 10 friends that is all planning to buy the same R/C car so we can all race against one another on a level playing field, mostly leaving vehicle setup and driver skill as the variables. I am researching which model would be the best platform to start with.
Ideally, it would come as a kit we can build ourselves. That will add to the fun of being able to assemble it, and set it up to our liking.
Requirements:
-1/10th scale off-road electric vehicle
-2S battery limit
-Total cost under $500 for everything
-Adjustability in terms of geometry and suspension (toe, camber, preload, droop, oil viscosity) and chassis (gearing, slipper) would be nice
-Usable on carpet track, and groomed dirt track.
So far, it doesn't look like I have many options:
-Traxxas makes the Slash kit for $199, and requires a battery and charger. It does look rather cheap, using a brushed motor and many plastic parts. - https://www.amainhobbies.com/traxxas...014-4/p1221983
-Associated makes the Pro2 SC10 for $399 including everything. This looks like a much nicer platform at a glance, compared to the slash. It is a not a kit however, so it doesn't even really meet my own criteria. - https://www.associatedelectrics.com/...ce_Wheels_RTR/
Is there something else I should be looking at that might get close?
Requirements:
-2S battery limit
Main problem with the Slash is that it is filled a ton of design flaws and has VERY dated technology, it requires more money on upgrades alone that make it far more expensive than a race grade kit... the kicker is that it doesn't even include sealed diffs which are critical for race tuning.
Check out PR Racing, they offer a wide range of entry level to high end kits where this should help you keep everything in the price range you need to be:
https://shop.thercproshop.com/pr-racing/pr-racing-kits
I would contact the owner (Scott Howe) and let him know you are planning to order 10 kits, he will likely give you a discount for a bulk order like that, tell him Bill DeLong referred you
Check out the TLR - Team Losi Racing
This was built for spec racing to be a little simpler. You can totally build this for your budget.
Hi guys,
Requirements:
-2S battery limit
-Traxxas makes the Slash kit for $199, and requires a battery and charger ... -Associated makes the Pro2 SC10 for $399 ...
Requirements:
-2S battery limit
The question is... Where am I going to find a radio + receiver + motor + ESC + battery + charger + servo + tires for $180? Does anyone know of affordable electronics packages that could be coupled with a kit instead of having to buy everything separately?
Since the two you have listed are Short Course trucks, is that a priority as well, or is buggy based a consideration as well? ... most of your 'kits' are not going to include electronics, so are all 10 in agreement on the electronic package, right down to the mAH/C rating of the lipo, etc.? ... an open playing field here ($$), so much for your 'set-up & driver skill' reason for the whole deal ...
Yeah that's what I'm seeing - I am not seeing a way to do a half-decent "kit" without it blowing the budget. Yet there are tons of RTR's that can be had for well under budget.
And yes, all 10 are in agreement to have the exact same batteries, motors, etc to keep things fair.
Buggy is definitely a consideration. Or a stadium truck or truggy as well.
With regards to 'building from kit', I would strongly recommend complete disassembly and rebuild anyway, as the RTR kits almost always are less than acceptable to be truly 'race ready' ...
So, you have said 'RTR-Kit', then mentioned building a kit. RTR means Ready-To-Run, which means it is pre-built and usually much cheaper. Which is more important? Building the kit or staying under $500? I think you will have trouble staying under $500 with any kit. You didn't mention if the $500 limit was to include the transmitter or not. If not, it gets a little better, but still not easy.
If you go with a RTR, that is the easiest way to keep everyone on a level playing field. Many of the better RTRs do allow for tuning and adjusting. The RB10 from Associated would be a decent choice for a RTR buggy for dirt, and would work OK on carpet.
I wish more people would get together like you and your friends are doing and do this. To answer your question, I believe that the Associated RB10 would be the #1 choice. Team Associated RB10 RTR 1/10 Electric 2WD Brushless Buggy (Blue) [ASC90031] - AMain Hobbies
The Associated Pro4 sc10 RTR is another very cost effective RTR. Team Associated Pro4 SC10 1/10 RTR 4WD Brushed Short Course Truck Combo [ASC20532C] - AMain Hobbies. If Losi is your brand, then the 22sct is very good as well for 199.00. Losi 22S SCT 1/10 RTR 2WD Brushed Short Course Truck (Magnaflow) [LOS03022T1] - AMain Hobbies
Hi guys,
Requirements:
-2S battery limit
Requirements:
-2S battery limit
I know you mentioned 1/10, but for the price range you are looking at, desire the option of a kit, and the conditions mentioned, I'd be very curious if the LC Racing LC12B1 1/12 4wd buggy kit would be up your alley. When we first got indoor RC going here, we had very limited space and started with the LC Racing EMB-1 vehicles. Fast forward a bit, the LC12B1 was released and we now have options for sensored motors in the turns that you see in 1/10. The kits at the time and I think still do come with a variety of sway bars and springs for tuning out of the box and I think include a servo too. Agree on a simple ESC that has the ability to reverse motor direction and a motor and lipo to use and you have spec racing. the tires can work very well for carpet and depending on the dirt surface could work there too. Car isn't that much smaller than a 1/10 buggy and is definitely bigger than Losi's mini-b offerings, much more stable, etc.
Even on our outdoor 1/10 turf track we have guys running these and they are missiles and jump amazing well for the size.
https://www.youtube.com/watch?v=M4WwPuEC8hA
https://www.youtube.com/watch?v=Ee2uaBo4jBo
Here is a link a lot of folks get there stuff from:
https://casterracingmi.com/index.php...roduct_id=1943
Another option if you guys are into the short course thing are these:
https://casterracingmi.com/index.php...roduct_id=1747
Take them apart and put them back together just like a kit lol. RTR brushless with lipo for about $300, just add battery. Can even get them with a clear body so you can paint what you want.
There are many RTR's that fit the bill, but I would really prefer to build the cars.
And it's looking like buying a kit + electronics is impossible to keep under $500. That's including transmitter and everything.
Got a link to the tracks you are planning to run on as well a dimensions?
We won't race exclusively at this track. We also have a loose dirt track. I think a SCT or Stadium Truck would fare better than the buggies on the loose dirt but it's still an option.
Sorry - that was confusing. When I said RTR-Kit, I kinda had in mind the Traxxas Slash kit which includes everything you need, but also requires you to build it. That would be ideal, but also seems like the only brand to offer such an option.
I think it will be a lot of fun. Thanks for the recommendations.
Nor Cal hobbies. https://www.youtube.com/watch?v=oeeKWAbdpHY
we ran on black dirt loose track here for awhile before getting our turf with buggies, and used to run 2wd buggies on a 1/8 scale track in the old days was good times, hard thing was finding tires.
https://www.youtube.com/watch?v=5jijWmbhJ4c&t=69s
Vid of the track we did the buggies on (not of the buggies unfortunately but we ran on this):
https://www.youtube.com/watch?v=RQeeJXUbctQ
You wont find what your list includes only option is Sash. I raced that truck for over 10 years sure it needs modes. steering rack. hubs .shock caps.but the upgrades are endless.chuck works chassis.and many more. ran the slice B on oval with 13.5 setup
Get Mini Z and an RCP track.
What are the priorities? If the main priority is cheap, then Slash is it. But it's cheap and nearly bulletproof. I know some guys can break an anvil in a sandbox with a rubber mallet, but I've not seen much breakage in the last few months of racing the stock slash class. Parts are cheap. The local track only allows the tx/rx to be changed, and aluminum shock caps. I've only seen one cap come off.
