Affordable 1/10th RTR-Kit for spec racing
#16
What are the priorities? If the main priority is cheap, then Slash is it. But it's cheap and nearly bulletproof. I know some guys can break an anvil in a sandbox with a rubber mallet, but I've not seen much breakage in the last few months of racing the stock slash class. Parts are cheap. The local track only allows the tx/rx to be changed, and aluminum shock caps. I've only seen one cap come off.
Budget price of the base vehicle is #1
Good platform worthy of upgrades. Don't want a cheap POS that is not worth upgrading over time.
Adjustability (no fixed plastic tie rods)
I think durability of any of these will be comparable.
I'm liking the AE Pro4 RTR. $400 for everything. Sealed gear diffs. Fully adjustable.
https://www.associatedelectrics.com/.../Pro4SC10/RTR/
or... the Traxxas Slash 4x4 Ultimate. It's at $499, right on the border. Maybe with a discount it will leave room for a battery and charger.
https://traxxas.com/products/models/...ate?t=overview
#17
Main problem with the Slash is that it is filled a ton of design flaws and has VERY dated technology, it requires more money on upgrades alone that make it far more expensive than a race grade kit... the kicker is that it doesn't even include sealed diffs which are critical for race tuning.
Check out PR Racing, they offer a wide range of entry level to high end kits where this should help you keep everything in the price range you need to be:
https://shop.thercproshop.com/pr-racing/pr-racing-kits
I would contact the owner (Scott Howe) and let him know you are planning to order 10 kits, he will likely give you a discount for a bulk order like that, tell him Bill DeLong referred you
KIts
#18
Moderator
What Bill said. That PR stuff is gunning for top end kits at half the price. Probably to get a customer base. If I had your budget they would be on my short list.
KIts
KIts
#19
I would strongly recommend against weird brands like PR. Assuming everyone is new to this, and the races will be more of a demolition derby than a race, I highly recommend you get a very popular brand that has easily gotten parts at your local hobby shop or online or whatever.
Especially if you're running buggy, nothing will kill someone's enjoyment faster than breaking an arm or hub or idler gear or spur or whatever and having to wait a week to fix it. The most important thing is to be able to keep everyone up and running with as little downtime as possible.
Pro2 SC10 or RB10 would be my choice, the 22 is a nice buggy, but about as "exotic" as I would go.
I also recommend you just buy one of whatever you decide on first and run it at the track to make sure it's what you're expecting. Short course on a carpet track rolls over super easily. Buggy on a dirt track requires a well groomed, well maintained track else they just get thrown about too much and it's not fun at all.
#20
I would prefer to stick with a major brand supported by the LHS. Traxxas, AE, Losi, etc
How about this alternate idea to get everyone driving but also satisfy those who want to build a kit from scratch:
The standard car (so that everyone can be included) will be the Pro2 SC10. Probably 8 out of 10 drivers will pick this route due to budget reasons.
If someone with a little more $ to burn wants a more bling platform and to build the kit, they can build an RC10SC6.2.
My thinking is: Both are 2WD. Both weigh the exact same amount and are the same dimensions. The only practical difference is the quality of parts, and mid vs rear motor.
Questions:
-Assuming the same battery/motor/esc/servo, would these two be competitive on the track or is this going to put one group at a major disadvantage?
Questions:
#21
To go along the lines of your alternate idea, we've seen success with a "Spec SC class" where folks can pick any brand of RTR 2WD SCT they want and then limit upgrades for durability only, no performance upgrades allowed. Only electronics that can upgraded are Radio, Servo and 2S LiPo ROAR spec. Must run box stock RTR wheels to prevent a tire war.
What we found was that of the 5 different brands out there at the time, folks would experiment with parts between brands to build the "Unicorn" because no single brand has the best of everything in one box
If you want to spec out the radio and servo to keep costs down I would consider these here:
$64 - Radiolink RC4GS
$41 - JX CLS6322HV
$34 - Zeee 2S Shorty
$42 - Tenergy 80W AC6 Charger
There is also a BTD kit from ECX to consider as well:
https://www.horizonhobby.com/product.../ECX03034.html
$41 - JX CLS6322HV
#22
$41 - JX CLS6322HV
$41 - JX CLS6322HV
#23
Questions:
Questions:
#24
Just a thought, but maybe a Pro2 SC10 or Traxxas Slash 2wd in either kit or RTR form as the choices ... creates a little brand rivalry, and much more similar than your rear/mid motor suggestion ... kit version available, as well as parts most everywhere, good used market for rollers if anyone is wanting to take even a more budget route (just FYI, the Pro SC10 is the same as Pro2 SC10 before name change) ... then all you need to fight over is an agreeable electronic/tire package that fits the criteria ...
Lots will scoff at any mention of a Slash, but tough to go wrong as a strong consideration in any budget/spec scenario ... in some forms of R/C racing (even among very experienced drivers), the 2wd Traxxas Slash is one of the fastest growing/most competitive classes, often limited to box stock configuration except for minor upgrades for durability and body changes for appearance...
#26
A lot of people are suggesting slash, but another option could be the Traxxas bandit 2wd Buggy.
This guys been running a YT series where hes been getting one racing and been doing quite well with it, to the point a lot of other racers bought one and they now have a Bandit class. His biggest hop up was tires that saw a 5 second change in laptime. May be an idea to pick a spec after market tire so the buggies are a bit more racey, but still prevent a tire war.
Link to latest vid in that series: https://youtu.be/Hgsqx45VLZ0
#27
The Bandit is not keeping up with the RB10 on the track. RB10 for the win.
#28
I would not consider the SC6.2 just 'a more bling platform' than a Pro2 SC10 ... very different vehicles under the body, much more adjustability, quick change diff option, superior shocks, etc. etc. ... there is a reason people are running 6.x vehicles most everywhere today vs. an early 5 series platform vehicle ... this would be quite a stray from the intentions and objectives expressed in the original post IMHO ... on very loose outdoor track conditions, the advantage difference would be minimized somewhat, but not "-Usable on carpet track, and groomed dirt track."
From your "to get everyone driving" comment, sounds like there may possibly be some with little or no driving experience? ...
I mean, the Slash unassembled kit fits the bill. It would work fine and is well within budget. The powertrain could be upgraded to brushless later on.
#29
I found this awesome tuning guide from Traxxas... this might be making the decision easier...
https://traxxas.com/news/slash-spec-racing-guide
#30
I highly recommend you just keep it to one make and model of car. The whole point is for the zero-experience people to just show up, drive their cars, have fun, not worry about who has a better car, or what they need to do to "fix" why they are losing all the time, or worry about spending more money because they think they need something someone else has, etc.
Also not sure why you want a kit if 75% of the people have never even driven an RC car, much less built one from scratch. Traxxas kits aren't that hard, but if you have zero experience and don't even know what an ESC or receiver is and have like an 80% chance of probably building the car wrong the first time. Trust me, people have enough problems even getting an RTR to run reliably.
Kits are great once you've had an RTR or two and have taken them apart and put them together a few times.
I get that you want to come up with something that the 25% of experienced people would enjoy, but remember it's the 75% you need to make sure have a good experience, so they keep coming back again and again and last long enough in the hobby to turn into the other 25%.
