Old 12-25-2002, 02:35 AM   #1
Default Duratrax 1/10 buggy...bad tank???
Hey guys,
My buddy just bought this buggy and we've been having problems keeping it running. It would fire and then die almost immediately.
We eventually traced it to the tank, or it seems. If we pump the carb primer on the tank right before the motor died it would continue running, otherwise it would die.
I've heard those primer pumps are a source for leaks. Is there any way to pressure test the tank? Could it be something else? I checked the pressure line from the exhaust and it looked OK.
Thanks!
John
jvannghi is offline   Reply With Quote
Old 01-01-2003, 08:39 AM   #2
Most likely the primer is bad. That is fairly common on tanks that have primers. You can cut off the top of the primer shaft, punch the remaining primer into the tank and remove it. Now just fill the hole that is left with a tight fitting screw (with a little sealer if you have it) and it should be fine.
Hank
Team RCV - http://www.teamrcv.com
hankster is offline   Reply With Quote
Old 01-01-2003, 10:26 AM   #3
Thanks Hankster, I'll give it a try!
John
Need Duratrax BX Pro Buggy Help! smarking1212 Rookie Zone 0 07-03-2008 01:09 PM
1/4 of a tank old LOSI 8 BUGGY nitro rat Australia For Sale/Trade 17 02-19-2008 01:28 AM
Painting Nitro Tank Lid (Duratrax Evader, Yellow..) Jeff221 Painting, Designs, Graphics and Photography 0 05-05-2007 10:39 PM
Trinity Spyder tank & Violator tank Hugh R/C Items: For Sale/Trade 0 07-21-2006 06:12 PM
F/S : DuraTrax 1/5 FireHammer Gas Buggy RTR JohnnyTCEO R/C Items: For Sale/Trade 0 06-02-2006 07:52 PM
