Team Associated RC8B4e
#61
So I went out testing today for the first track test of the rc8b4e and i feel the front of the chassis digs in way bad. The track has a kicker and the bumper would literally gouge the face, as well as the face of a fast triple too. Is anyone else having issues like this. I ran my Serpent E buggy, as well as my Nitro buggy, SCTE3.0 and B74 and no other car i have digs the jump faces and landings like this. I tried several changes, to try and help, but even with the front end almost at full extension at ride height, it still did it. I feel like the front block and chassis are too far out front of the wheels and not enough chassis kick up.
#62
What battery pack are you running? I am now thinking of running the shorty 4s all the way back if this is an issue. Maybe a regular 4 s will be the only way to fix this with more weight in the rear to balance it out. You sure raised one hell of a red flag. How come this never came up before??
#63
#64
Motor size???
Hello. Is the 1900kv motor still the "go to" motor for E buggy? I will be racing on a large low/med grip hard packed track. Should I still go with the 1900kv or something like a 2200kv motor? Thanks for the advice
#66
Motor mount??
I was looking at the motor mount and didn't see any type of rubber padding or anything on the inside of the motor mounts. Is the mount a one size fits all thing. How does the mount compensate for the slight differences in motor diameters? Will I have any issues using the 4268 hobbywing g3 motor? How does the mount keep the motor from rotating in the mount? Thanks
#67
Battery mah size??
Are 5000mah shorties enough for this buggy or is a larger mah battery needed. I will be running 7 minute qualifiers and 10 minute mains. What about the bullet size...is 4mm bullets enough or is 5mm bullets needed?Thanks
#68
Everyone i see runs 5mm bullets. What size track ? Small indoor track and a light trigger finger maybe 5000mah. We run outdoor large track and i can get 10 mins out 6000mah. I see some racers run out of battery with 7500mah on 10 min main it comes down to smooth trigger finger.
#69
I picked up some 11 gauge wire from TQ Wire and used it for battery to esc and esc to motor. The motor runs much cooler with this set up.
#70
Multiple brands wheel fitment issue?
I thought I read somewhere that there was a wheel fitment issue with front wheels. I can't remember where I read it to confirm it but the writer says that multiple wheel brands rub were the turnbuckle is attached. Can anyone confirm whether this is true or not? I like to run sweep wheels and tires. That is one of the supposed wheel brands that rubs. Thanks
#71
#72
I had AKA wheels rub the rear hub, not the front. AE and Avid wheels work just fine.
#73
Kurt
#74
I did get it all built and raced it this past weekend for the first time. Man, it drives amazing. I think I'm better with it than I was with my Kyosho MP10e. Both are saddle pack configurations, but the AE I think better suits me. Pillow balls vs. C-hubs.
