Ultrasonic Cleaner
I’m in europe so I cant recommend one But I usually go for 8 minutes at 40 degrees celcius. You can also run metallic parts if you DRY them with a hairdryer or compressor after. If you have a lot of small nuts and screws I put them in a tea strainer in the machine.
I have the HF cleaner and its ok. I feel like its not working as well and its about 8 months old. I did get the 2 year warranty, and Im going to exchange it. Might do that today actually.
I'd google around for different brands though. If you can deal with a smaller one you can search around and find them for good prices and probably better quality.
I run this guy with a warm 50/50 mix of Simple Green and water. Works awesome.
Cheap Ultra-Sonic Cleaner
I think the default is 320 seconds. Usually that, sometimes I'll start it twice. Its not rocket science. If your parts are clean that's enough time. I throw in anything dirty (especially greasy diffs when I'm doing a viscosity change). It comes with a plastic basket to hold all your parts and the holes in the basket are a little large. I often have to fish small washers etc out of the bottom. With the Simple Green all the grease floats to the top. I usually drag the top of the liquid with a paper towel to soak up the grease before pulling the basket out otherwise it just re-coats all the parts. Greasy dirty plastic comes out looking brand new! The cleaner is well worth the $40 IMHO.
***Oh, I just remembered. I read somewhere that you should not put bearings in an Ultra-Sonic cleaner. The vibrations pit them or something. Other guys do it. YMMV.
I have been using this cleaner here for a while now:
I don't have any experience with any other cleaners, but the one I've been using has met all my expectations. I mostly use it to clean my wheels after removing the tires with acetone, the wheels come out looking nearly new again, minus all the scuffs... the cleaner doesn't really get into deep scratches so I have to use a brush, but it's really a lot less work than not using the cleaner at all.
Depending on what I'm cleaning, I often find that washing my parts under hot water from the sink is more than sufficient, but if that can't get it done, then I'll break out the ultrasonic cleaner for heavy duty cleaning.
Some wheels have been so dirty that it took close to an hour to get my desired result, and if there are too many deep scratches, then I don't bother and simply toss out the wheel than to waste my time.
Here is a vid of Adam Drake using the cleaner:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
--Alex
I think that might be a typo... I don't think it's a good idea to let it cycle THAT long, I typically would let if go for a few minutes at a time and check the parts never finding it necessary to go more than 20 min total per set of parts. Unfortunately I can't test it right now because the cleaner is in storage as I'm currently fulltime in an RV traveling abroad for a while. I do plan to get into my storage next month to clear out some stuff and if I can locate the cleaner I'll confirm the 99 min cycle works.
--Alex
