Calcium grease for R/C car differential >
Like Tree2Likes
  • 2 Post By fyrstormer
Old 12-04-2021, 03:04 AM
Default Calcium grease for R/C car differential
Can calcium grease be used for metal differential gears? Is it safe for the plastic housing?
cookieoreo18 is offline
Old 12-04-2021, 03:28 AM
fyrstormer's Avatar
It should be fine, but silicone grease will give you more of a limited-slip action. Or if the differential has O-ring seals, silicone oils in a wide range of viscosities are available to fine-tune the differential's limited-slip action. You probably don't want a fully open differential, like you'd get with any kind of petroleum grease, if you care about performance at all.
fyrstormer is offline
Old 12-04-2021, 03:46 AM
thanks for the help. Btw i recently casted a custom differential locking block from HDPE plastic. So i do not care about any "limited slip" functionality.
Old 12-04-2021, 05:37 AM
Trader Rating: 16 (100%+)
If you are locking the diff, why put grease in it at all?
Or do you mean on the transmission gears?
Silverbullet555 is offline
Old 12-04-2021, 07:43 AM
what? There are still gears in the differential. The ring and pinion gears need to be lubricated
Old 12-04-2021, 08:35 AM
gotcha. I'm thinking internal diff spider gears. For the ring and pinion pick whatever you have.
Old 12-05-2021, 01:48 AM
fyrstormer's Avatar
OHH. I thought you were talking about the internal spider gears too. For the ring and pinion gears you want the slipperiest grease you can find.
