Are there any 4WD sand-rail buggies?
I really like the styling of my Arrma Raider. It looks like the way a buggy should look, to me -- narrow, with a heavily-reinforced "rollcage" style chassis instead of a wide flat chassis. I also liked the way the Vaterra Glamis Uno looked, for the same reasons. But both of those buggies are RWD, which limits their drivability in loose conditions -- I mean really loose, like sand or grass, as opposed to a clay track with a layer of dust on it.
Are there any sand-rail buggies with 4WD? I know space is at a premium in such narrow chassis, but that's not an insurmountable problem as far as I'm concerned. I know about the Kyosho Optima, but I already have one of those, and it's still kinda wide due to the transverse battery mounting.
You just need sand paddles. I used to take my old outlaw rampage pro to the beach with buggy paddles on it (the nitro stadium truck from the 90’s, not the retarded sht for sale now) - it ripped. Couldn’t even imagine what it would have been like if I had the option of proper size paddles like we have today.
Kyosho Javelin?
Sand paddle tires work very well...on sand. Maybe okay on grass, I dunno. They don't do well on mixed terrain. That's the real advantage of 4WD -- I don't have to change tires every time I want to run on a different surface, which means I can drive on any surface I come across while I'm outside.
The Kyosho Javelin does look good, but I already have an Optima, so...I dunno. It's a little small too, and hanging the motor off the rear axle is a neat design but isn't the greatest for stability in when cornering hard. But it might end up being the only option that has 4WD with a properly narrow chassis.
I have a Losi Ten-SCBE already -- the predecessor to the Tenacity. It's a nice buggy, especially once I increased the suspension travel and removed the wing which was threatening to break the rollcage from all the hard impacts it was absorbing when the buggy would flip at high speed. But yes, as you say, it doesn't look like a sand rail buggy at all.
You can just buy the body parts of the Javelin and fit them to your Optima AIUI. And then wallah, a cage buggy.
Or be a big boy and step up to the Hobao 1/8 Nitro cage buggy.....
The proper tires for the proper terrain will get you far.
There is no tire that is good for every terrain. Especially sand, sand pretty much needs paddles.
There is no sand near me. I refer to the "sand rail buggy" design because that's what it's called, but I drive all my RCs on a mix of dirt, grass, and pavement. For that terrain I get along pretty well with motocross-style tires like the Pro-Line Badlands. Unfortunately they don't make them in buggy sizes.
Which one? The hobao or the Javelin body set? There's a link above for the hobao,
The javelin body set is available from a bunch of places, kyosho usa, amain, rc mart.... Although you'll also need the metal side pieces, that's harder to find....
1. Losi Tenacity: 1/10, 4wd, sand rail style buggy, but still has a flat chassis
2. Axial Exo Terra: 1/10, 4wd, sand rail style buggy, not as durable as the Losi but cool design.
