Hex Adapter for Traxxas Bandit >
Like Tree2Likes
  • 1 Post By Clark
  • 1 Post By ta_man
Old 10-13-2021, 01:52 PM
Default Hex Adapter for Traxxas Bandit
I was looking to replace the wheels and tires on the Bandit and it looks like the font wheel hubs are only the axel pins. What is the group recommendation on using hex adapters for the wheel hubs? How much of the thread do you really lose when you install these adapters? I don't want to be locked into using the Traxxas wheels and then mounting tires to that.
hans1128dog is offline
Old 10-13-2021, 02:32 PM
the rc guy's Avatar
figure it out. the hexs are what a tade under 1/4 " you can use a thinner hex nut
the rc guy is offline
Old 10-13-2021, 07:36 PM
Just get rustler axels and wheel hexes. The front wheel hexes are wider than the rear on a rustler, so you might want to get rear hexes.
AHR43 likes this.
Clark is offline
Old 10-14-2021, 06:43 AM
Backyard RC's Avatar
You should have 12mm hexes on the front and rear axles. Sometimes the plastic hexes get stuck in the wheel and come off, leaving only the axle and pins. You shouldn't need to get new hexes to change wheels unless you're going with a wheel that uses a 14mm or 17mm hex.
Backyard RC is offline
Old 10-14-2021, 09:02 AM
AHR43's Avatar
+1 on the plastic hexes sticking. TRX at one time offered aluminum 12mm hexes. I have a pair on the rear of one of my Rustlers. Don't know why they wouldn't work on a Bandit with Rustler FR axle, shim and pin set-up.
AHR43 is offline
Old Yesterday, 11:30 AM
ta_man's Avatar
Trader Rating: 166 (100%+)
Clearly spoken by someone who never had a Bandit.
RazorRC likes this.
ta_man is offline
