Old 06-29-2006, 09:18 PM   #301
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
i have? o.o
i think ive seen a solid red tc with white rims a couple of times at socal though..
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 06-29-2006, 09:24 PM   #302
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
Originally Posted by RC Guru
i have? o.o
I think Jose also has a solid red car too...
killer89 is offline   Reply With Quote
Old 06-29-2006, 09:27 PM   #303
SoCalLosiRacer's Avatar
i have? o.o
I put pictures of my buggies up in the XXX-CR thread, and I figured you've probably seen them. I guess not
SoCalLosiRacer is offline   Reply With Quote
Old 06-30-2006, 01:42 AM   #304
JasonD7's Avatar
Default Hey JasonB
I just saw the picture of your XXXcr. I just finished mine and painted it too.
check out the attached jpeg.
JasonD7 is offline   Reply With Quote
Old 06-30-2006, 02:39 AM   #305
Looks good.
Love the wing
Are you going to race sunday?
Old 06-30-2006, 10:13 AM   #306
lookin good! looks like you used that 1/8th scale wing! hahah wicked!
-valentin
www.csjunkies.com
Old 06-30-2006, 03:22 PM   #307
JasonD7's Avatar
Default About Sunday
I planning to be there, running stock. I have family coming in all the way from Georgia, it could screw things up. I will definately be there tomorrow to set up the XXXcr. Later.
Old 06-30-2006, 04:59 PM   #308
i might be there...no promises..but if i do come..i wanna see that xxx-cr man!! its alright if you dont come, ill just hack tyler.
-valentin
www.csjunkies.com
Old 07-11-2006, 12:22 PM   #309
jaejw1's Avatar
Send a message via AIM to jaejw1
what amount of anti-squat are you guys using on the track,, went there lastnight and not only did i have 2 degrees antisquat ( i usually run 0-degree) but i was also using tires that have been grooming in a plastic bag for a week ,after spraying them with wd40.. im sure the combo of very soft front tires (proline blades) and the 2 degree antisquat made for a very strange ride.. the car(I) was all over the place ...
was is typically used.. seems i had too much steering and it made it hard to correct while on power..
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 07-11-2006, 12:47 PM   #310
Casper's Avatar
Trader Rating: 34 (100%+)
jaejw1-- What car are we talking about and what rear tires are you using. I have never needed to sauce front tires at So Cal. I never needed that much steering. I have been using the the stock 2 deg in my CR and I am runing 1 deg on my MF2 truck if memory serves me right.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-11-2006, 04:17 PM   #311
jaejw1's Avatar
well im the one with the xtm xcellerator with the gtb 5.5 ,,, the only oddball out there..
i was, before the change, using 0-degree antisquat, proline m3's and r3's ,, losi ribs ( i think they are pink,, and they are pretty old.. ) my shock oil is also less in rear than front i think by 5wt not much,,
i thought i could get more control from the car by adding antisquat and also the tires was just an experiment.. i am using proline holeshots R3.. they felt softer than M3's,, but i have noticed that when the track is blue'ish like it was lastnight i tend to always have problems,, but this time it was a lil more noticed.. i have a video of it,, the only thing though with the video, one of the wires soldered onto the BL motor was fraying off inside the insulation ,, my guess only a few strands were still connected which made the truck slow... but looking at the drive you could still see my bad driving.. too bad i dont have anything else from before. for some reason my driving is better the first week (actually the first day) of a new layout. http://www.youtube.com/watch?v=nnvfKuogFIM
motor review
tire review
Old 07-11-2006, 05:22 PM   #312
Casper's Avatar
First off losi never made the 9 row in pink. (with they would) so you tires are probably silver. (a good tire for socal). R3 is harder then M3. R3 is a good indoor clay dirt tire and will be faster for lap times since it is harder but unless you have a good setup on the truck it will be a little harder to drive. M3 tires are a little more forgiving a tire and is probably a better choice for a drier track. Less antisquat should give you more side bite but from the video it looked like you car was loose on power (or exiting the corners). I would put the antisquat back and maybe move out on the tower for the rear shocks as this should help the truck square up better on exit.
Old 07-11-2006, 05:57 PM   #313
jaejw1's Avatar
the only options i have for antisquat are 2 and 3 degrees... the associated might fit and im not sure how the losi's look.. bu like i was saying with the 0-degree antisquat i was able to throw the car around and make it do what i wanted.. and the r3's were very soft since they were sprayed with wd40 and sealed in a ziploc bag for over a week.. im not used to anti squat and i probably did too much at one time... very soft front tires along with going from 0 to now 2 degrees was more than confusing for me to drive..
with the 0-degree,, i was able to lift the front end up (most of the time wheeling down the straight) high enough so it wouldnt affect steering that much,, but i was always going straight and the front end had a controlable push that i liked..
i dont know of anyone that has drivien with 0-degree anti,,, i was actually told not to do it..
i will try it again with the front ribs ,, to take out some of the steering, and keeping the anti squat the same 2- degrees,, like someone told me once ,, "push is good, as long as you can control it"
motor review
tire review
Old 07-11-2006, 07:46 PM   #314
Casper's Avatar
You do not need a new block to change antisquat. You can add and take away antisquat by using thin shims under the front or rear of the block which will adjust the angle. (FYI)
A car that pushes is usually more consistant as it forces you to slow down for corners. Consistancy wins races. If you have to much steering or the car is loose, this can be fast only if you can control it. Spining out in the corners is not fast. Antisquat is something that is hard dangerous to play with. Depending on if it is adjusted wrong for your setup or suspension geometry you can loose all rear tracion (fwd and side) with antisquat changes. That has been my experience at least.
Old 07-11-2006, 08:59 PM   #315
jaejw1's Avatar
it could just be my sorry a$$ driving..lol.
motor review
tire review
CVR-Central Valley Raceway-MADERA,CA Official thread stevenmichael Track Locator Forum 43 06-05-2014 12:27 PM
MADERA R/C RACEWAY OFFICIAL THREAD stevenmichael Track Locator Forum 351 09-11-2008 09:04 PM
The Official-Unofficial Tamiya America Raceway Thread! Leester Racing Forum 0 02-06-2007 02:29 PM
*Official SOCAL raceway* offroad thread Cash-Money Racing Forum 1 04-05-2006 05:00 PM
