Team Associated RB10 RTR >
Like Tree59Likes
Old 04-01-2024, 04:42 PM
  #121
nrtv20's Avatar
Carbon is preferred in carpet off road
nrtv20 is offline
Old 04-02-2024, 04:41 AM
  #122
Originally Posted by AntH3000
It's fine, my kid has given it a beating and it holds up. Plastic moulded chassis were used for decades in top line race chassis.
I didn't expect plastic chassis can be use for so long
foosoomin is offline
Old 04-02-2024, 02:00 PM
  #123
A well designed plastic chassis can be very strong. The biggest issue is you often have to screw into the plastic, so over time those screws can expand with the cycles of taking them apart and reassembly. Iíve only ever had a plastic chassis failure with the original Clodbuster & that was running it in winter where the cold makes the plastic more brittle. Given they are much cheaper than aluminum or carbon chassis, this is usually still cheaper.
nielsm is offline
Old 04-02-2024, 04:42 PM
  #124
nielsm
So we still can consider RB10 though
Old 04-03-2024, 04:44 AM
  #125
Of course. It’s a good value way to get started in 2WD buggies. It’s based on the B5 which was a competitive racer for many years. The rear motor setup won’t be as fast on high grip tracks as it will have too much rear weight bias. But, if you are running on real dirt or just bashing outside, it’s a great option. And if you are running on high grip tracks, it’s still a low cost option to get started & see if you like it.
AntH3000 likes this.
nielsm is offline
Old 04-04-2024, 05:59 PM
  #126
nielsm
I own a Team Associated B7 now........
So now i am considering a rear motor mount 2wd buggy...............RB10 comes into my mind
Old 04-04-2024, 07:12 PM
  #127
Originally Posted by nielsm
The rear motor setup wonít be as fast on high grip tracks as it will have too much rear weight bias. But, if you are running on real dirt or just bashing outside, itís a great option. And if you are running on high grip tracks, itís still a low cost option to get started & see if you like it.
Rear motor car won the 21.5 class a month ago at the Desert Classic. Mid motor fad almost done.. rear motor bouta take over...
MaX-D and nielsm like this.
will5879 is offline
Old 04-05-2024, 01:34 AM
  #128
Why do you think Associated released the RC10 CC? Itís making a comeback and will surely be at the top of the podium, even with all the brittle clear parts. Some top AE drivers are swapping their new B7 for the OG RC10 . I should have kept my gold pan I raced in the 80s!
But seriously, a good driver can win with any car. Thereís a YouTube series about a guy running a Traxxas Bandit in his local club races as a joke & doing well. While mid motor will be faster around a high grip track than a rear motor with the same driver, itís not like itís twice as fast.
nielsm is offline
Old 04-05-2024, 09:26 AM
  #129
A few years ago I was running my old B5 and doing extremely well against modern cars in 21.5 / 17.5. Started as a joke there too but kept running it because it was hooked up, comfortable and easy to drive, and just a tick off the pace of the fastest guys far as lap times go. A single mistake wiped out any advantage there in a 5 minute race. If I go back again I might stick some B7 KPI stuff on there, could drive even better..
Mac The Knife and nielsm like this.
will5879 is offline
Old 04-06-2024, 05:47 PM
  #130
That guy should get a commission on new bandit sales. Way more about the driver than the car
nielsm likes this.
leadfootedfool is offline
Old 04-10-2024, 01:38 PM
  #131
I raced my RB10 this past weekend as well as my mid motor car. TQ'ed mod buggy with the mid motor and the RB10 actually TQ'ed over the mid motor car by 1 second. So properly setup they are no slouch.
Beasty Shout and MaX-D like this.
jz97ss is offline
Old 04-10-2024, 07:47 PM
  #132
Beasty Shout's Avatar
Are there clear bodies available for these? Canít seem to find any. Wonder if B4.2 bodies fit?
Beasty Shout is offline
Old 04-11-2024, 07:56 AM
  #133
A tamiya DT02 sand viper body is a close fit. https://www.youtube.com/watch?v=jONlng77Gh8
Beasty Shout likes this.
baconracer is offline
Old Yesterday, 01:41 PM
  #134
Changed the servo out for a Savox as the standard servo saver is pure junk in every respect, and broke also. Thought I may as well use a decent servo and alloy arm. Was getting receiver brown out so had to use a power cap plugged into the aux channel. That solved it. In case anyone else thinking of switching to a high power servo.
BlueCollarRC likes this.
AntH3000 is offline
Old Today, 03:10 PM
  #135
Good info to know as new servos are #1 on my upgrade list.
Is a power cap a capacitor?
BlueCollarRC is offline
