Old 04-02-2006, 06:18 PM   #1
quietstorm76's Avatar
Default Best way to remove tires from rim
Hey guys please help. I bought a new set of tires and for once glued them perfectly. Bad news is the pin striped the wheel. I don't want to throw them away it's a new set of Gladiators. What's the best way to get them off the rim?
quietstorm76 is offline   Reply With Quote
Old 04-02-2006, 06:55 PM   #2
Preheat oven to 400degrees, turn off oven let wheels sit in oven for 10 minutes or so. they should peel right off.
WWW.RCRARACING.COM
wake is offline   Reply With Quote
Old 04-02-2006, 06:56 PM   #3
Place them in boiling water for about 5 minutes. This will loosen the glue, you can wait till they cool before you pull them apart.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 04-02-2006, 07:01 PM   #4
Thanks a lot guys. I'll give both ways a try.
Old 04-02-2006, 07:35 PM   #5
Trader Rating: 14 (100%+)
put the in the oven, but it wuld be best if you had a toaster over that was on the crappy side that way you could take it OUTSIDE.
When you bake them, you might have to replace the foams, on a few I have done I had to anyway.
o.s. power is offline   Reply With Quote
Old 04-02-2006, 11:45 PM   #6
If you boil them you will need to replace the foams. Oven baking seems to be gentler to them.
AreCee is offline   Reply With Quote
Old 04-03-2006, 12:26 AM   #7
Trader Rating: 8 (83%+)
if u put it in the oven wont the rubber melt from putthing them on a hot metal rack?
i730 is offline   Reply With Quote
Old 04-03-2006, 01:43 AM   #8
SpeedBump57's Avatar
Aceatone is the way to go if you are not going to use the foams any longer. Fill a tub with aceatone place tires in fully covered and let sit over night with lid on the tub. When done the tires will fall off the wheels and there will be no left over glue what so ever on the wheels. I did the oven thing for a long time and although it works the aceatone works much better.
Note: do not do this with the pink tapper pins though. For some reason they do not like it and will shrink and get hard.
When done just pure the left over acatone back into the jug and reuse.
SpeedBump57 is offline   Reply With Quote
Old 04-03-2006, 10:42 AM   #9
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
I have never boiled or baked off tires. So, can someone go indepth on how to boil off a set? Thanks if you do.
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 04-04-2006, 09:48 PM   #10
Sp1ke's Avatar
Send a message via ICQ to Sp1ke
hey guys... got this from a site... credits go to Eric from Misbehavin' RC.... a step by step guide to removing them.... http://www.misbehavin-rc.com/pit-lan...ling-tires.asp
Sp1ke is offline   Reply With Quote
Old 04-04-2006, 09:56 PM   #11
Is there a way for me to save the foams ? if there brand new
Matthew.H is offline   Reply With Quote
Old 04-05-2006, 01:18 AM   #12
TheTurtleMan's Avatar
Trader Rating: 31 (100%+)
Yes. Just cut the tire off if you don't need it any more. Take foam out, them boil, or bake wheels.
CLICK HERE FOR ALL YOUR RADIO AND MORE SKINZ!!!!
http://www.rctech.net/forum/showthread.php?t=184104
WWW.BUSTOUTBMX.COM
TheTurtleMan is offline   Reply With Quote
Old 04-09-2006, 09:07 AM   #13
HotrodHopkins's Avatar
Send a message via AIM to HotrodHopkins
tha'ts a great link, now i know what to do, hehe.
so ur sayin basically you can save one or the other, not both?
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 04-09-2006, 11:40 AM   #14
Sp1ke's Avatar
i think that the best way is to save the tyre cos you might have other uses for it (cut them into bands to create thick bands to hold your tyres in place while gluing) but i cant think of what else to save the foam for... which is cheaper to replace? foam or tyres? not a difficult toss up...
How To remove Tires from wheels cheesecake Nitro Off-Road 34 02-24-2008 09:50 AM
whats the best way to remove tires??? Mugen MBX-5 Nitro Off-Road 27 10-30-2007 09:43 PM
How to remove water from truggy tires? SuperEk4 Singapore R/C Racers 10 05-16-2007 08:54 AM
How do you remove glued tires from wheels? Mr.Maim Rookie Zone 28 03-08-2007 09:50 AM
how to remove CA from tires coolrcdad Electric On-Road 12 03-06-2003 10:51 AM
