Old 11-22-2006, 12:31 AM   #31
Default metal bottom diff gear
I have the metal midler but does someone make a bottom metal gear--I have one in my nitro evader even though it never broke a gear but the ep keeps frying them, breaking out the centers ----------- anyone??
gitigowland is offline   Reply With Quote
Old 11-22-2006, 10:55 AM   #32
Default Nitro ST Evader for SALE
I have a spare Nitro St with a modified and lightened chassis plate and all new parts, except for the shocks. Has doubled up rear shock mounts (graphite) and alot of trick tweaks on it. New arms front and rear, spindles, rear hubs with new bearings, cv axles, new transmission and slipper, battery box, reciever box with power switch, new Futaba throttle servo, servo saver, engine mount and front bulkhead with doubled up hinge pin retainers and front shock tower and body mount. it needs steering servo, engine, body, shocks and some tires to complete. $150.00 shipped. I will try and get some pic up soon---
[email protected]
Old 11-22-2006, 10:33 PM   #33
RAZ49's Avatar
There used to be a company selling a diff gear for the AE that fit some what. I tried one but it stripped out the alum idler in no time. They are about 2 mm smaller and the teeth are more rounded. I would rather buy a new diff gear at a couple bucks over new alum idlers. Just tighten the diff up TIGHT so it won't melt out the center. There is a spool coming out soon that iliminates the diff but may not be to good for racing, just bashing and drag racing.
RAZ49 is offline   Reply With Quote
Old 11-24-2006, 04:59 PM   #34
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
lets keep this thread going lol
MADMAN23 is offline   Reply With Quote
Old 11-25-2006, 07:41 AM   #35
RAZ49's Avatar
Why do we need 2? There is already a thread for the Evader.
Old 11-27-2006, 02:47 PM   #36
MADMAN23's Avatar
2 better then 1
Old 01-06-2007, 05:35 PM   #37
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
AE type slipper for my Ele ST.
Remove the slipper setup from truck keep parts in order so you can reassemble as needed.
The inner slipper plate remove the lip that holds the slipper pad in place.
Get 1 set of AE B4/T4 slipper pads AE#9603 (they come two in a pack).
Get a AE#9654 87t spur (IF that is the size you use)(AE only offers 81, 84 and 87 tooth spurs)
1. Put inner slipper on truck
2. Then a slipper pad
3. Then spur gear making sure slipper pad is in its placement on gear.
AE manaul states to "press pads into spur gear" have 3 AE trucks and I've never had them stay in the gear as I assembled the slipper!!
4. Second slipper pad
5. Outer slipper plate
6. The rest of the washers/spring/nut in the order you removed them.
NO you do not use screws to mount spur gear, its between the slipper plates not on the outside of the outer plate.
7. Adjust slipper nut as needed.
Have done this on my Evader MADE a big diff at the track! Much smoother under power and coming out of turns like my Race AE T4.
Motor? Axiom "Blueprinted EPIC Cobalt 27" stock ESC and radio!
Is could be a GREAT upgrade for someone running BL, slipper pad area is about 600% greater!!!
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Duratrax Evader EP Dogchaser Electric Off-Road 11 10-20-2009 05:07 PM
Duratrax evader bx Fenwick R/C Items: For Sale/Trade 4 01-31-2008 03:25 PM
ft/duratrax evader st pro rtr . trade for duratrax vendetta . MADMAN23 R/C Items: For Sale/Trade 1 01-09-2007 08:50 AM
Duratrax Evader BX rickyboy44 R/C Items: For Sale/Trade 0 03-11-2006 08:43 PM
Duratrax evader st hop ups Nemo Rookie Zone 2 09-28-2002 08:05 AM
