Old 04-01-2006, 04:04 PM   #1
morris's Avatar
Trader Rating: 40 (100%+)
Default fantom fr .12
hello,
i just purchased an fantom fr .12 engine for my losi xxxnt.
was just wanting to know what the better GLOW PUG for that engine.
i took the one out that came with it but it does not say anything or have any numbers on it.i compared it to a o.s.#8 but looks to be a little longer than a 8.i have always used to use cvr's in my truck but decided to go with a little more kick!!
so any info you might have for me leave a note.
thx,
matt
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 04-02-2006, 12:26 AM   #2
is it the one with the turbo head? if so then any turbo plug for 1/10th off-road will be fine.
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 04-02-2006, 07:50 AM   #3
Use McCoy MC59 plugs, they're inexpensive, the correct heat range and Fantom even recommends using them if you can't find Fantom plugs. Another option is the OS A3 plug, it's the same heat range as the MC59.
AreCee is offline   Reply With Quote
Old 04-02-2006, 07:00 PM   #4
morris's Avatar
thx for all the help with this!
i will try one of each and see which i like better.
thx guys,
matt
Old 04-02-2006, 07:36 PM   #5
Trader Rating: 14 (100%+)
yes, the fr 12 is a turbo head
o.s. power is offline   Reply With Quote
Old 04-02-2006, 11:28 PM   #6
That's funny because the FR12/slide carb non-ps I have uses a standard plug like the MC59. And since morris took his out to compare it to an OS #8 and the Fantom plug is a little longer then you have to assume that it's a standard.
Old 04-03-2006, 04:48 AM   #7
morris's Avatar
yea my engine has the red head on it that says fr.12.has the red aluminum collar on it.um but i dont read anything anywhere stating its turbo engine.
it has the rotary carb on it.side exzaust..maybe this wil help clear things up a little....
thx again guys,
matt
Old 04-03-2006, 08:26 AM   #8
Forgot to mention that the Fantom plug I have is a thread longer than the #8.
Morris, a #8 is too cold to use in the .12, you a much better off with a MC59 and 20% nitro. Mine runs all day at 235-250 degrees and has a nice power range.
Old 04-03-2006, 11:01 AM   #9
then it must be an older engine because the fr 12 '05 is a turbo head.
Old 04-03-2006, 01:24 PM   #10
morris's Avatar
i did some investigating and came to coclusion that fantom has the fr.12 with rear exzaust.i beleive this is the turbo model.mine is the staright up normal engine.so im thinking that the mc-59 or a a3 should work fine.
thx again,
matt
Old 04-03-2006, 03:22 PM   #11
Well Morris it should be easy to see the difference. A turbo plug is tapered at the end by the filament and a standard plug is straight and threaded all the way down.
The 05 FR12 could be either Side Exhaust or Rear Exhaust and the stock head button is a turbo for both. Fantom offers an optional standard plug button for extra cost.
However, it sounds like you have an older engine as I do which doesn't use a head button and does use a standard plug.
Old 04-03-2006, 06:09 PM   #12
morris's Avatar
thx...i pulled the plug and it is a standard one.looks the same as the os8...
so thx for all the help guys...
matt
Fantom Done? Jake S Electric Off-Road 15 08-14-2007 12:28 AM
Thunder Zapper Fantom Dyno Fantom Lathe Spring dyno Brush Butcher Fussy full monte HenBeav R/C Items: For Sale/Trade 8 12-06-2006 11:38 AM
FS: 05' Fantom .18 scr_achy R/C Items: For Sale/Trade 1 11-29-2005 02:59 PM
12 used fantom monster & fantom binary balanced stock motors 2 epic roar stock brand jason cheng R/C Items: For Sale/Trade 11 06-06-2005 08:23 AM
Fantom FR-12 Sofast-NT Electric Off-Road 7 11-03-2004 04:56 PM
