Dogbone pins
On ebay you can find all sizes needle bearing pins.
Times past I used a dremel to cut lengths off a 2.5mm hex driver shaft to get 2.5mm pins. Admittedly, that was when I really needed one in a hurry. Worked well enough I never replaced it with a "proper" pin. Good luck. Cheers. 'AC'
I believe they are 2.5 x 9.8mm which is common for most 1/10 cars, I've been very happy with 6MIK pins, they're hardened steel:
https://dialedhobbies.com/accessorie...-8mm-10-detail
More info here with some various tools to consider:
https://www.ebay.com/itm/2-5mm-M2-5-...8AAOSwwWtcwVaE
Why buying something from an RC brand while you can get 5 times as much for even a lower price:
I feel that the pins from RCRenew are about the same quality as the pins from 6MIK, only issue I have with the RCRenew pins is that they have a coned end which can be problematic when pressing the pins and just doesn't look right to me... the 6MIK pins are perfectly cylindrical on both ends.
