TLR 22.5 Elite Gear Diff setup for indoor clay track >
Like Tree2Likes
  • 1 Post By skife
  • 1 Post By Antimullet
Old 02-17-2021, 01:37 PM
Thumbs up TLR 22.5 Elite Gear Diff setup for indoor clay track
I would like to see if any of you are running the G2 Gear diff on the 22.5 Elite when running on indoor clay or dirt tracks?
I know a majority of you are using ball diff. I just wanted to test something different, easier to maintain.
I just ordered a new G2 gear diff and I would like to experiment with different diff silicon oils: 200,000, 500,000 and maybe 1,000,000 cst.
Based on the researches I made so far, Kevin Gahan at TLR mentioned the late Brian Kinwald was using a gear diff with a 500,000 cst silicon oil at the Horizon track in Illinois and was planning to use 1,000,000 cst when the track is really slippery.
Thanks!
joxes is offline
Old 02-18-2021, 08:04 AM
The newly unveiled 22 5.0 dc race roller uses 7k in the gear diff.
Rcdad42 is offline
Old 02-19-2021, 04:15 PM
Indoor clay I've been running 35wt.
Rcdad42 likes this.
skife is offline
Old 02-22-2021, 06:45 PM
Trader Rating: 65 (100%+)
IMO you’ll always give up performance on dirt using a gear diff. They just don’t generate enough grip.
What are your times between rebuilds on the ball
diff? I have over 10 races on my ball diff and haven’t had to rebuild it. It’s silky smooth still.
a gear diff the oil is dirty after two races. Less maintenance with a ball
diff.
thecman26 likes this.
Antimullet is offline
Old 02-22-2021, 09:27 PM
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
On clay a well set-up ball diff is far superior and actually requires less maintenance!
thecman26 is offline
Old 02-26-2021, 06:39 AM
You would go up in CST for a slippery or a track with less traction? Not sure if that is correct. Is it possible you would go down to 100,000 CST for a slippery track if you went to a ball diff?
BuddyLee303 is offline
Old 03-02-2021, 09:33 AM
Iím guessing that Kinwald was running a gear diff because he thought the performance was better than a ball diff. And the new losi buggy has a gear diff, it does make me curious.
taylorsizemore is offline
Old 03-02-2021, 10:00 PM
Some people at my local high bite indoor clay track are experimenting, and liking, running gear diffs in both stock and mod cars. 2 gear, 60k seems to be the starting setup.
Bicycle019 is offline
Old 03-03-2021, 11:44 AM
RC10Nick's Avatar
Back when the dex210 was a thing I spent an entire race season chasing setups trying to get a gear diff to work on a med grip indoor clay track. I didn't realize at the time it was the gear diff causing me issues. I was dead set in thinking a gear diff must be just as good as a ball diff. I was wrong.
One weekend I tried swapping back to a ball diff. I was instantly faster. I learned my lesson. If I'm on dirt, I'm running a ball diff. If you build it right, set it right, and don't abuse it, it will last an entire race season.
RC10Nick is offline
