Shock Springs 1/8 Scale ??
I have some shock springs that got mixed in with some 1/10 scale buggy springs that I had purchased a while back, only they are wider and thicker wire than for 12mm big bore AE shocks, possibly 1/8 scale?... they measure 17.5 inside, 21mm outside, 46.5mm tall and wire is 1.65mm thick ... can anyone identify by size what the application would be? ... thank you
16mm 1/8 shock current standard, should fit inside a 17.5mm ID and the spring should be fully seated on the preload collar.
