Brushless upgrade problems
Just upgraded my car to brushless with a 4370kv motor and a 60A ESC. Sold together as a package. Paired with a DumboRC 6x and 6xfg receiver.
Running 2s lipo 3500mah 7.4v
Regardless if I'm driving on tarmac, grass, snow....fast or slow, at 25% or 100% and even gentle throttle while on a stand with no resistance. After several minutes the car comes to a stop. ESC still running but no drive or steering. If i turn the transmitter on/off nothing. Turn the ESC on/off then it works agin for several minutes then repeats the cycle?
Transmitter programmed
Battery charged
Reciever and transmitter bound
Whats going on?
4370kv motor drawing more than 60A and shutting down ESC?
The Specification of the Motor:
KV:4370KV
Watts:800
Max Voltage:<12V
Max Amps:66A
Rotor Poles:4
IO:3.2A
Resistance:0.0185
Max RPM:50000
Connector:4.0mm gold
The Specification of the ESC:
Cont.Current:60A
Burst Current:360A
Motor Type:Sensorless Brushless Motor
For 6s Lipo or 6 cells NiMH
1.On-road 3660-size or smaller motor with the kv <4300
2.Off-road/buggy/monster 3660-size or smaller motor with the kv <3300
For 3s lipo or 9 cells NiMH
1.On-road 3660-size or smaller motor with the kv <3300
2.Off-road/buggy/monster 3660-size or smaller motor with the kv <2600
Suitable Car:1/10 car
Resistance:0.0007ohm
Battery:2-3 cells lipo/4-9 cells NiMH
BEC Output:5.8V3A(switch mode)
Battery charged
Whats going on?
KV:4370KV
Watts:800
Max Voltage:<12V
Max Amps:66A
Rotor Poles:4
IO:3.2A
Resistance:0.0185
Max RPM:50000
Cont.Current:60A
Burst Current:360A
Who makes the ESC? Have you programed the temperature cut off? Or Battery voltage cut off?
Battery charged
Whats going on?
KV:4370KV
Watts:800
Max Voltage:<12V
Max Amps:’66A’
Rotor Poles:4
IO:3.2A
Resistance:0.0185
Max RPM:50000
Cont.Current:’60A’
Burst Current:360A
Battery charged
Whats going on?
KV:4370KV
Watts:800
Max Voltage:<12V
Max Amps:’66A’
Rotor Poles:4
IO:3.2A
Resistance:0.0185
Max RPM:50000
Cont.Current:’60A’
Burst Current:360A
Its thermal ling. .
if you read specs #1 clearly say Under 4300kv u have a 4370k that's Over the esc limits.
get a better esc or a lower turn motor
