Best. 12 engine for 1/10th Gas Truck
We are reviving 1/10 gas truck at our local track this summer!
which .12 roar legal motor do you consider to be the best? Rear or side exhaust, slide or rotary carb?
Keep price in mind, so best motor for the buck. Because I know i can get a great motor if I plop down 300 bucks, but I also like to find out what is the most economical choice that is reliable and preforms great on the track.
OS CVR WITH A ROTARY, APPROX $120.00 2 YEAR WARRANTY AND IT WILL BE DECENT ON MOST TRACKS, YOU MAY WANT SOMETHING FOR THE BIGGER TRACKS WITH SUPER LONG STRAIGHTAWAY.
I HAD THE TR MOTOR, GOOD MOTOR MOST MOTORS OUT THERE HAVE A TON OF POWER AND GETTING THAT POWER TO THE GROUND IS HARD. I BELIEVE IN THE ASPECT OF HAVING A LITTLE LESS POWER MAKES IT EASIER TO DRIVE. WHEN I HAD THE TR I HAD TO TURN DOWN THE POWER. COULD NOT PUT IT DOWN. MOST OFF-ROAD TRACKS FOR GAS ARE ROUGH AND 1/10TH SCALE TRUCK HAS ALOT OF FINESE WITH IT. I AM VERY HAPPY WITH PERFORMANCE OF THE CVR. ONE THING TO REMEMBER IS GAS QUAL AND MAINS ARE LONGER TIME WISE. YOU HAVE MORE POWER THAN YOU NEED WHICH MAY LEAD TO SLOWER LAPS OR A BROKEN TRUCK. I SEE GAS TRUCK AND 4WHEEL DRIVE ELECTRIC BUGGY AS YOU HAVE TO HAVE WAY TOO MUCH POWER WHICH LEADS TO PEOPLE GETTING DISCOURAGED AND QUITING, IF THEY WOULD SLOW DOWN A LITTLE THEY WILL GO FARTHER AND FASTER
My position is pretty much the same. if it has too much power, I don't mind turning it down a bit, because that means your running cooler when your not using the engines full potential. That translates into loger engine life.
Anybody know anything on the picco .12 which I believe is the same as the Omega x12. any info on either motor?
Pick up a fully modded o.s. cv-r w/ a rotary carb. It will come equipped with the best carb in the market. The motor mods amazingly well. A good mod will put out around 1.3-1.4 hp and give you around 15-20 minutes of run time. For a price tag of around $200 its unbeatable. If you don't have the extra $100 for a good mod from a company such as eb mods then the normal cv-r will be a very solid choice. As far as pipes are concerned I would go with the adam drake edition pipe that comes with the ad2. It is cheap and has a very very smooth power band. Unless you run on a big track then odds are you will never use the full power band of your motor. The cv-r is also an engine which you can tune once and it will run like a champ as long as the temp doesn't change 20 deg. The biggest thing that leads to the discouragement of 1/10 is the diffs and slippers. Make sure someone w/ a good head on their shoulders can help to educate the locals on how to properly set theirs up and be of assistance in the pits. When you have a properly set up 1/10 scale they are so much fun to drive. I would also try and run the track wet so that tires last longer.
The CV-R is a great choice, puts out plenty of power for most tracks. I have a RB C12 in my AD2 and it kicks ass. I can pull the front wheels up at will. Another really good motor is the Novarossi CX12 R2 - this is the second generation of the MT12 that Mugen made, which was quite possibly the best motor at the time.
I wouldn't look at any other motors but these. Don't be tempted by the OS TZ, way to much for offroad.
