Kyosho MP9e Evo v2 Readyset as a Basher >
Old 11-11-2020, 10:07 PM
maxxreign's Avatar
Default Kyosho MP9e Evo v2 Readyset as a Basher
I'm looking for another 1/8 buggy to bash with. I currently have a Typhon 6S that I only run 4S on. Thus, 6S vs 4S is not an issue for me. I'm really interested in the Kyosho MP9e Evo. What are your thoughts of it as a basher? Thank you.
maxxreign is offline
Old 11-12-2020, 11:52 AM
OffRoadJunkie's Avatar
there are a ton of aftermarket parts for it and it jumps really well. Ground clearance is an issue due to it being designed for tracks. However, slap a chassis protector on it and go. You can also add bigger tires to give you a little more ground clearance. If you do put taller tires on it, just make sure to use a heavier shock oil so your shocks don't bottom out.
OffRoadJunkie is offline
Old 11-13-2020, 12:11 AM
maxxreign's Avatar
Thank you. This is great information.
Old 01-02-2022, 11:02 AM
raullomi's Avatar
Hi
I just bought a mp9e evo v2 and I would like to know the configuration that RTR brings, liquids, adjustments etc but I have not found a sheet with it from the factory, only blank and confirmation from other users.
Is there a place or sheet where I can see factory settings?
raullomi is offline
Old 01-03-2022, 05:23 PM
Did you purchase a used one or a new one? If you purchased a used one, you can download the build sheet from Kyosho.com.
Old 01-05-2022, 12:53 AM
raullomi's Avatar
It is a new model, but the manual does not contain a sheet with the fluids that it carries in differentials or shock absorbers. on the Kyosho website I have only found the blank sheet or from other brokers, but not the rtr configuration
raullomi is offline
Old 01-05-2022, 10:27 AM
You can ask the question on Kyosho.com. It can take a few days to get a response, but they always responded to my questions.
Old 01-11-2022, 11:53 PM
hi
I recently purchased an MP9e evo v2 and would want to learn about the RTR setup, including liquids, modifications, and so on, but I have not found a document from the factory with this information, only blanks and confirmation from other users.
donalexinder24 is offline
Old 01-12-2022, 01:25 AM
raullomi's Avatar
I sent inquiry to Kyosho and they told me this:
Sorry for the late reply.
I think the Readyset MP9E comes with grease in the diffs I would recommend silicone oil for more consistent feeling.
Please find attached a set up which is quite a good all round set up.
I can not upload the photo or put a link because the photo says that I have few posts
raullomi is offline
