AE RC8 B3.1e from kit has bind
AE RC8 B3.1e built fresh from kit. I thought I did all the steps , but must have missed something.
When rotating the front left wheel in full droop or fully compressed the outdrive forces the arm (up/down) via the drive shaft. This creates a wobble/hop or completely binds when attempting to drive.
I checked the out drive - it is the 17mm one with 94 mm shafts. I have disconnected the sway bars with no affect. Everything else looks right.
I am stumped...any thoughts?
Thanks!
Thanks!
Sounds like a part that has been installed incorrectly somewhere in the front end.
Check that the upper and lower arms are in the correct orientation and on the proper sides, and that the bearings in the steering blocks are fully seated, and that the steering block arms are in the right places and orientation.
Check for bind without driving the car as you work on this!
is the CVD pin in the slot as it should be?
AE still uses set screws in it's cvd's?
I dont lock those. Wheel should hold the pin in if setscrew fails.
I never run more than one battery without swapping a hex. That's my first tuning aid in practice. Usually juggling +2 and 0 hexs.
