Team Associated T6.2
#376
The Hudy setup is $$$$, but I like it.
#377
I used most of the setup from the carpet guy on PetiteRC.
I was running brass 30 gram front weight and changed it to stock 10 gram bulkhead.
truck handled much better but was more squirrelly than before. Like less rear traction.
Normally guys at my track use 15 k in gear diff but I used 10k per setup sheet.
only ran a Few packs but getting there. So thanks.
#378
Rcamerica has the top plate in stock(checked 10/26/22). I have the same system, and got my top plate from them.
#379
I am running on grey carpet, i have the Jovy Levin setup on the truck and am have some traction roll issues when going hard into a couple 90deg turns. I did notice once i got home that i didn't have the front sway bar hooked up.
Should this help my issue?? I really wish i would have noticed this at the track, the truck is pretty good everywhere else, i just can't lose this much time in the corners if i have to slow down as much as i was so i don't traction roll.
#380
#381
Not seen this info posted anywhere yet.
#382
Thanks, good job 👍
#383
T6.3?
Has anyone heard anything on weather AE is going to come out with a T6.3?
#384
I guess it has been a couple years now... so they could slap 13mm shocks on the T/SC, update the box art... and announce a T6.3 and SC6.3?
#385
2 weeks
#386
Super Moderator
Chassis kickup to match the 6.4 line
Front Shock tower change
Rear Shock tower change
Bell crank adjustability like the 6.4 line
Caster and Steering blocks like the b6.4 line
Chassis shape similar to the b6.4 line
Wider C and D blocks, similar to the b6.4 line
Longer dog bones, 92.5
13mm shocks front and rear
Now the question that I have is do we really need 27.5 and 36mm shocks on the T/SC?
#387
Wouldn't it be cool if there was more to a new SC6.x. Maybe have it come with 2 chassis, so it can be a T6.4 and SC6.4? Not sure what else they could do? Update the Body mounts and bumpers?
#388
When building a t6.2 is there any difference building one for turf/carpet vs building for dirt or is the setting changes in the manual
#389
Yes. Carpet and turf are very different, so try and get a setup sheet from a fast local driver or a recommended setup from a pro to start with. You'll at least need a gear diff to start with bare minimum as a ball diff wont survive the grip. Well unless its wet turf but thats rare.
At least figured out what kind of carpet (grey, black, "office" etc) and find a setup sheet that matches.
#390
Hi guys. I just picked up my first t6.2 the other day and got to drive it. I'm racing on astroturf at Larry's R/C.
Its a very fun car but I've noticed even with the brand new prisms it likes to spin out I've driven a b74.1 on this track and its impossible to spin it out. I'm wondering if this is a setup deal or how stadium trucks usually run. I've got it used so I'm not to sure what's
in it for setup.
If anybody has a setup they would chare for carpet/astro or any driving pointers would be highly appreciated!
in it for setup.
