Which ESC/motor combo?
Should I do this ESC/motor with the 5400kv or the 4000kv?:
https://www.hobbywingdirect.com/coll...nt=27757683857
I will be using a 2s lipo. Will the ESC burn up on the 5400kv?
What are you driving?
It makes no sense for a manufacturer to pair an esc with a motor that would burn out the esc. Your concern of such is very puzzling to me.
Sorry Its a Yokomo YZ-2 Cal3. What pinion should I run with the 5400kv motor? And whats the difference between this esc:
https://www.hobbywingdirect.com/prod...nt=26983763784
And this esc if I use the 5400kv motor as well:
https://www.hobbywingdirect.com/prod...nt=20187925828
The difference between the two esc's is that the first one is 2s-3s and the second one is 2s-4s with more current capacity as it is for heavier short course trucks. The second one probably wouldn't fit in a 2wd buggy as the space for electronics is very limited. Neither esc is sensored, which is something I don't like for a 2wd buggy esc.
I dont understand anything about what you said about timing. I dont want a refurb esc I want brand new. Since its 2wd that hobbywing esc/motor will have too much torque or what?
The only use I see for 4-pole motors is in 4WD Short Course. Also sensorless is not really what I'd recommend in any 2WD vehicle, especially on a racetrack. Bashing, maybe - but a Yokomo caL3 is not really a bashing vehicle either...
Suspended
I would get these
https://www.amainhobbies.com/hobbywi...112608/p982997
and
https://www.amainhobbies.com/hobbywi...401111/p742120
these will be perfect for you
and
I cant spend that much Cmgreen.
waitwhat: I want hotter than a 17.5t. What would be equal to 3300v?
What about this with the 3300kv motor?
Also, what tooth pinion do I want for a cooler motor. I dont want extra speed more worried about a cool motor.
17.5t motors are around 3000kv, 13.5t motors are around 3600kv. The timing setting on the motor and timing added by the esc let you adjust the kv. That Tekin esc in that last link can add up to 55° of timing, which would put a 17.5 right around 3600kv. There are 7 timing profiles pre-loaded into the esc giving a single adjustment to tune your power level.
If you go with a 4-pole sensorless system you will be on your own to figure out gearing. The YZ2 was designed to run 2-pole sensored motors, so the gearing recommendation in the manual and any gearing info from setup sheets is based off 2-pole sensored motors. If you are under geared the motor will be hot and slow. In that case a larger pinion would make the motor run cooler. If you are over geared the motor will be hot and fast. In that case you need a smaller pinion to make the motor run cooler.
Ultimately, you won't know if your gearing is right until you drive the car.
If you’re on a budget go with this combo. It’s much better suited for a 2wd buggy and is sensored.
https://www.hobbywingdirect.com/coll...=2139725987868
Use the 120 esc, 17.5 motor for stock or whatever for mod. It’s a good cheap system
All the sensored stuff is too complicated for me! I don't think I could figure it out.
