Am I nuts or are all 25T servo splines not the same?
I have pretty much always used Hitec servos but I got a deal on here on a few Protek servos. I figure hey, I don't need horns and they have good reviews so why not. Well, the Tekno clamping horn I had on the Hitec would NOT fit the Protek. I then tried another non clamping horn that fits the hitec and yup...didn't fit the Protek. The Protek's output is 25T but it is beefier. I wasn't expecting that. I opened up a new Tekno 25T clamping horn and it did go on but was/is VERY tight. Should I only use Protek horns with Protek servos?
Hitec used to have 24T in the past. Futaba (and most others now) have 25T. Maybe check that out?
Some of them are pretty darn tight. My 22X-4 horn was a pain to mount on my MKS servo, I use a little black grease sometimes so they slide on smoothly.
I've ran the following 25T spline servos with the TEKNO horns, all of them fit like a glove without having to do any "spreading" of the horn:
- AGF --> currently my favorite brand of servo
- JX
- Power HD
- Savox
Hitec was 24T in the past and they moved to 25T only 3-4 years ago with their new line up. If you have one of their older servo's, it could be a 24T spline.
As far as I could find, those two Hitec servos seem to be 24T indeed.
Manufacturing tolerances.
I also have a few 9370's and those were the first gen to have the 25T spline.
Location: northern Indiana southern Michigan all depends on the day.
hitecs use both 24t and 25t servos. the majority are 24t , but the 9xxx line are 25t. if its not a 9xxx line its probably 24t.
https://gearsolutions.com/features/inside-splines/
The answer is "Yes," you are nuts and "Yes," the splines can be the same, but sizes can be different. 2mm shaft with 25 splines or a 2.5mm shaft with 25 splines.
