Old 03-24-2006, 09:37 PM   #1
Suspended
Default help on the tamiya tlt
i just finished the TLT...but when i try to run it...it does not move...when i pick up the truck,it spins freely...when i put it on the street or grass ,i can hear it turning,the motor whining but the truck does not move...please help....i dont understand.....red
could it be i have somethiing reversed?or a bad servo?or esc?everything is brand new...please help////
redneck15 is offline   Reply With Quote
Old 03-25-2006, 02:33 AM   #2
nsr250repsol's Avatar
Send a message via Yahoo to nsr250repsol
Most likely it is one of two things: Either your pinion gear is not tight on the motor shaft or your pinion and spur gear are not tuching. check those two things and I'm about 95% positive you'll find the problem. Good Luck!
“Warm beer is infinitely colder than no beer”
nsr250repsol is offline   Reply With Quote
Old 03-25-2006, 06:35 AM   #3
Suspended
i checked and they are touching,i am gonna take it apart and tighten it more...the funny thing is that sometimes the back wheels spins and sometimes it does not...could it be the diff?
Old 03-25-2006, 07:15 AM   #4
you might not have tightened the center diff enough.
baih is offline   Reply With Quote
Old 03-25-2006, 10:10 PM   #5
Suspended
it seems that i tightened it and it not turning correct,so tonighti will loosen it a bit to see if that is the case,,,damn!
Old 03-26-2006, 05:45 AM   #6
when you push your TLT you should feel the drag from the motor. If you push your TLT and you feel little or no drag look at the drivetrain to see where slippage is happening. This will give you a better idea of where to start troubleshooting. Let me know what you find out maybe I can get you pionted in the right direction. The center diff sounds VERY probible though.
Josh
Old 03-26-2006, 06:38 AM   #7
do not loosen it . if it starts slipping, it will heat up and melt the diff gear.
i already did that. lol you might have put it in backwards and as your driving it will loosen the diff nut. its been awhile since i worked on mine so i dont remember if it is possible to put it in backwards. check it.
add the rear steering. i used a servo reverser connector so i did not have to do mess with the radio.
Old 03-26-2006, 07:26 PM   #8
Suspended
well guys,i took out the center diff,it was so tight,it did not move...i loosened it a little bit ,not too much and behold,everything is working fine....thanks a lot for all your input...i just hope i did not loosen it to much...
Old 03-26-2006, 08:14 PM   #9
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
That's weird. Most people have the diff tightened all the way down without any problems. Some rock crawlers put a screw through the diffs to get rid of the diff action all together.
If you find out anything else that might have caused it, let us know
ModRC.com
sim600 is offline   Reply With Quote
Old 03-27-2006, 07:59 AM   #10
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
My TLT-1 Has locked diffs Works much better
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 03-27-2006, 08:02 AM   #11
Suspended
ok now when i run the TLT...the reverse is awesome but when i punch the throttle on forward.it runs sluggish...damn,now what....
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
