Team Associated B74.1
#301
Hi.
Anyone had this?
My b74.1 steering sometimes stays on a bit after turn. I have to adjust with trim 3-6clicks. After that it works fine for awhile and then happens again.
First thought it was fault on servo but other servo do the same.
E:everything is ok, nothing is broken when visually checked. Without servo, steering moves totally freely.
Thanks!
Anyone had this?
Thanks!
#302
Hi.
Anyone had this?
Thanks!
Anyone had this?
Thanks!
But more likely you’ve cracked a front hub and a split only opens up enough for it to flex under load.
Alternatively, if you’ve ruled out the servo (which it sounds like a dodgy potentiometer) it could be the transmitter.
#303
Hi.
Anyone had this?
Thanks!
Anyone had this?
Thanks!
#304
Hi.
Anyone had this?
Thanks!
Anyone had this?
Thanks!
#305
Servo horn first was stock plastic and i was thinking that it skipped a tooth but changed to alloy and same happens.
Transmitter was used on other car before b74.1 and no faults in there
#306
It took me a month of replacing parts in the front end until I found it. Pull the servo, servo mounts, and top plate out. Reassemble everything out of the car. Loosen the servo mount screws about a quarter turn. If you can move the servo around you have the same issue I did, and you need to fill in the holes in the servo ears.
When the screws were fully tightened, I couldn't get the servo to move. A slight pipe tap was enough of a shock to make it shift in the car.
#307
Here's the part number your looking for: ASC27128. From what I've heard they are not a universal fit. The servo ear tab holes can be slightly different sizes.
Wow!
Will check this asap
#308
Have to order those adapters on next time when in need some on my lhbs.
#310
Sorry to dredge up an old topic...
I'm looking at the original B74 rear arms, and comparing them to the supposedly updated #92130 rear arms I got directly from AE back in November. They look identical to me.
Can someone clue me into the physical differences in the rear arms I can look for?
#311
#312
R/C Tech Elite Member
Edit: MrLean beat me to it....
This was recently talked about in the RC10B74.1 Nation FB page, so I'm stealing the pics from there.
#313
#314
Suspended
#315
I put these washers in last night and the problem seemed to be solved. I’ll be sure to put it to the test with some nice wall impacts.
