E-Buggy motors
Old 07-30-2020, 01:13 PM
Location: northern Indiana southern Michigan all depends on the day.
Default E-Buggy motors
I'm taking a pull on what kva people like running I there e-buggy And why?
thanks
killer rock is offline
Old 07-30-2020, 02:47 PM
Trader Rating: 101 (100%+)
at the track you will find over 75% of people (on a race day) run 1900KV on a 4s. This combo provides good runtime (10 minutes or better), without overheating and provides a balance of punch vs. top end. I personnaly run 1800 because that's what my used car came with. I enjoy about 2 minutes more runtime than my buddy with a 1900 and the same batteries.
TimF is offline
Old 07-30-2020, 03:13 PM
Furadi's Avatar
Yeah I'm kinda the same. Running 1800kv but because I run castle and the other option is 2200kv. I have similar top speed to everyone else but I can get a solid 12 minutes out of my 440g SMC 5200mah packs.
Furadi is offline
Old 07-31-2020, 03:24 PM
ta_man's Avatar
Trader Rating: 162 (100%+)
On 4S in a buggy I've run anything from 1800 to 2100. One car right now has a 1900, the other a 2100.
For part of a season I tried a 1400KV on 6S (geared the same as my 2100 on 4S). 2100KV on 4S is the same RPM as 1400KV on 6S and I ran both setups with the same gearing. The 6S setup is commonly thought to run cooler than an equivalent RPM 4S system but I did not find that to be the case.
ta_man is offline
Old 07-31-2020, 03:41 PM
I'm running 2050. Most of the time part throttle but when I want to pull someone in, I have the extra power there that isn't being relied on from the ESC.
F1nalized is offline
Old 07-31-2020, 11:12 PM
I have a the Tekin T8 1900kv in my buggy. Most the other guys at the track do as well
Njeffs8 is online now
Old 08-01-2020, 06:30 AM
Furadi's Avatar
Right typically if RPM stays the same higher voltage will always pull less amps and run cooler. I was running a CC 2650kv up until a few weeks ago. My amp draw went from around 105a down to 70a and my temps came down from 200F to about 140F.
Furadi is offline
Old 08-01-2020, 09:56 AM
ta_man's Avatar
Well, the amp draw went down in my 6S setup (3600 battery instead of 5400 battery still gave me 12+ minutes) but the temps didn't. I was surprised by that given what I read.
ta_man is offline
