Old 04-15-2006, 09:13 PM   #46
mechmikee's Avatar
Some comments to you guys about the ST-R:
Shock Oil - 600 to 700wt in front & rear...I think 800wt is a bit much.
Diffs - 5 to 7,000 in front, 20 to 30,000 in center(20 for .21, 30 for .28 or bigger) and 3 to 5,000 in rear.
Ride height - Front bones level, Rear bones slightly above level.
Use Pavidas' shock and camber link positions, but I do like running the outside on the front arm/hub.
Comment on the notchy diffs: Some Conical(ring) gears may have clearance issuses with the height of the inside part (under where the larger diff gear rides). I have built 4 kits now, one for myself and 3 for customers and I have had problems with 3 of the 4. Options: Build it normal and run it in(1 to 3 tanks). However, change the oil, inspect the gears and rebuild. Should be good to go. Or . . . use 2 diff gaskets and follow previous comments...
I think the ST-R has great potential . . . we just had a trophy race here at out shop and I set TQ 2 of the 3 rounds with a 13 5:18 and 13 5:16 with my Hybrid Kyosho Truggy. I built the ST-R and raced it the next weekend (same layout exactly) and TQ'd with a 13 5:08.... End of story.
Mike Phillips
www.kyoshoamerica.com
www.raceaka.com
www.lunsfordracing.com
mechmikee is offline   Reply With Quote
Old 04-16-2006, 10:39 AM   #47
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
what about this for shock and diff setup
front 7
center 20
rear 2
shocks
50 frnt
60 rear
will that be good? i watched a str this past weekend with 7,10,3 but it looked like it needed more rotation center off so i figured i needed to drop it to 2.
he also had
40 frnt shocks
and 70 rear shocks looked smooth on the track
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 04-16-2006, 09:19 PM   #48
1 Xtreme R/C's Avatar
Trader Rating: 17 (100%+)
I just got done building mine. All I had was Losi oil 40wt, is that going to be thick enough?
1 Xtreme R/C is offline   Reply With Quote
Old 04-17-2006, 04:43 PM   #49
mechmikee's Avatar
front 7
center 20
rear 2
shocks
50 frnt
60 rear
he also had
40 frnt shocks
Sounds ok . . remember, setup is not a "one suits all" kind of thing. Different tracks may require changes, also to suit different drivers as well.
2 in the rear sounds ok . . . or maybe change rear toe? raise rear ride height? rear wheelbase?
Mike Phillips
www.raceaka.com
Old 04-17-2006, 04:45 PM   #50
mechmikee's Avatar
Probably not....You'll want at least 50wt.
Start where your are at and see how it goes. If it feels too soft or bottoms out too much, then go up on the oil weight.
Mike Phillips
www.raceaka.com
Old 04-17-2006, 06:14 PM   #51
macnkitty2002's Avatar
macnkitty. why are bow ties more appealing over the crimefighters. i heard the crime fighters have more side bite? i am new to 1/8 and or truggies as i now have purchased a st-r and starting to build.
sorry for the misunderstanding. i meant that the crime fighters are more preferrable over the bow ties. you are right about the CF's having more side bite. however, the bow ties are better for harder packed, blue groove surfaces, while the CF's are better suited for medium to hard packed surfaces with a little loose dirt on top.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 01-13-2007, 10:50 PM   #52
GMartinez's Avatar
Trader Rating: 85 (100%+)
Im in the process of building my STR & was wondering if anyone had some helpful hints since I already have a few suggestions on certain areas. last time I built a truck was like 3 years ago & so far Im 6 hours in & I just finished installing the motor & pipe. will try to post some findings & pics soon
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-19-2007, 10:21 PM   #53
Default stripped servo gear
Just got a used st-r in great condition, but I keep stripping my servo gear. I've stripped the one plastic gear in the servo 4 different times. The servo is a ko propo 2144 and i've never had a problem with it on my revo. I even stripped a newer version of the servo 2366 (i think). I thought the servo saver was too tight but i've backed it out (or up) all the way. Any help or suggestions would be appreciated.
I'm gonna try and rebuild the steering rack per the instructions but i don't see anything visibly wrong with it. If this still doesn't work can i just tighten the servo saver down and put a servo saver horn instead of the stock aluminum arm? Can anyone recommend one that isn't too soft that will cause the car to push or too hard it'll strip more gears?
Thanks in advance.
Ryan
rai13 is offline   Reply With Quote
Old 01-20-2007, 06:37 AM   #54
GMartinez's Avatar
Thanks in advance.
Ryan
I spoke to a couple of drivers & they had the same problem when using an aluminum horn
Old 01-20-2007, 09:03 AM   #55
That's interesting because I stripped out a Hitec S-5925 and a JR DS-8450 but the Futaba S-9351 just keeps going and going without a single problem race after race using an aluminum horn. Go figure.
BTW: JR repaired their servo for free, Hitec charged $15 plus $7 shipping.
AreCee is offline   Reply With Quote
Old 01-20-2007, 09:19 AM   #56
GMartinez's Avatar
that's because it's a futuba
Kyosho Truggy NIB jacsac R/C Items: For Sale/Trade 10 06-03-2007 06:19 PM
kyosho rtr truggy reddishdsb Electric Off-Road 11 12-17-2006 08:28 AM
Kyosho Truggy suntok2 Electric Off-Road 2 10-12-2006 12:12 AM
KYOSHO MSR 777 TRUGGY tmaxxking R/C Items: For Sale/Trade 17 09-07-2006 11:41 AM
NEW KYOSHO TRUGGY SR-T redneck15 Electric Off-Road 23 05-02-2006 10:33 PM
