Old 03-31-2006, 03:12 PM   #16
mjd
mjd's Avatar
Trader Rating: 23 (100%+)
got the tony screw set and the truck yesterday. Need Knuckles and front upper and lower alloy blocks to build mine. Tomorrow I guess.....
mjd is offline   Reply With Quote
Old 03-31-2006, 03:22 PM   #17
Trader Rating: 24 (100%+)
Default kyosho
mjd,
new to nitro,
what upper and lower blocks are you referring to? why alloy? for durablity?
vic0280 is offline   Reply With Quote
Old 03-31-2006, 03:34 PM   #18
More for bling since the stock plastic parts work well. (At least they do in my buggy). Maybe the knuckles make sense due to the greater load those larger tires and wheels will impose.
AreCee is offline   Reply With Quote
Old 03-31-2006, 08:05 PM   #19
are the knuckles the same as the 777? i was just gonna order a set of king headz.
Old 04-03-2006, 11:03 AM   #20
Just finished assembling my ST-R. The front knuckles look to be the same as the SP2. Anyone found a setup for this truggy yet? I built mine to the included factory setup.
What is the tire of choice on a high percentage clay track? Bowties or crimefighters?
One bonus of the kit... the unused parts on the trees look like they can be used for spares for my SP2.
shad
shadp is offline   Reply With Quote
Old 04-03-2006, 12:15 PM   #21
macnkitty2002's Avatar
crime fighters have worked beautifully for me on clay and even dry dirt.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 04-03-2006, 02:35 PM   #22
Default 777 ST-R
alright guys as i am trying to patiently wait for my tonys screw kit and steering knuckles to arrive,
how are you building the kit, to kit specs with everything or going with a different setup.
i found Mark Pavidis' setup but diff oil and shock oil seems really high. i will be running outdoor on a loose dirt track
Old 04-03-2006, 08:37 PM   #23
ttr_racer's Avatar
Where did you find Mark Pavidis's setup? Can you post a link?
ttr_racer is offline   Reply With Quote
Old 04-03-2006, 08:50 PM   #24
go to truggyracers.com... under kyosho.
Old 04-03-2006, 09:49 PM   #25
mjd
mjd's Avatar
777 SR1
Front:
- 700w Kyosho oil
- 1.4 pistons
- White springs
- Second hole from outside on shock tower
- Second hole from outside on suspension arm
- 20 deg caster blocks
- 10,000 front diff oil
- front ride height bones level or slightly below
- middle hole on caster block
- B mount on bottom
- High position for upper arm
Center
- 50 tooth spur
- 13 tooth clutch bell
- aluminum shoe
- 15,000 - 20,000 Center diff Oil
(This is with a .21 motor. If a .28 then settings will be different
but I have not tried)
Rear
- 800w Kyosho Oil
- 1.4 pistons
- Blue Spring
- Outside hole in tower
- Second to outside hole in suspension arm
- 2 deg anti squat block
- 2.5 rear toe block
- hubs all the way back
- camber link is in inside middle hole in tower and outside hole in
hub
- lower hole in rear hub
- 2,000 - 4,000 diff oil
Old 04-04-2006, 05:37 PM   #26
AZRCaddict's Avatar
Originally Posted by Shocker
Here's a few pics I took earlier of the ST-R in progress. Sorry about the quality, they're from my phone
Team EMB
AZRCaddict is offline   Reply With Quote
Old 04-04-2006, 06:10 PM   #27
holy crap! those driveshafts are long!!!!
Losi Rock Rey
Old 04-05-2006, 02:10 AM   #28
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Cheers
Drift_Buggy is offline   Reply With Quote
Old 04-05-2006, 02:10 AM   #29
Like to see how much new ones will cost
Cheers
Old 04-06-2006, 03:45 PM   #30
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
how much more difficult is the str to put together then a 4wd touring car? or a 2wd buggy? those are all ive put together. also about how long of a time frame will it take me 5hrs?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Kyosho Truggy NIB jacsac R/C Items: For Sale/Trade 10 06-03-2007 06:19 PM
kyosho rtr truggy reddishdsb Electric Off-Road 11 12-17-2006 08:28 AM
Kyosho Truggy suntok2 Electric Off-Road 2 10-12-2006 12:12 AM
KYOSHO MSR 777 TRUGGY tmaxxking R/C Items: For Sale/Trade 17 09-07-2006 11:41 AM
NEW KYOSHO TRUGGY SR-T redneck15 Electric Off-Road 23 05-02-2006 10:33 PM
