Wheel hexes for 8mm axles? >
Like Tree1Likes
  • 1 Post By fyrstormer
Old 06-26-2020, 12:07 PM
fyrstormer's Avatar
Default Wheel hexes for 8mm axles?
I'm looking for some clamping aluminum wheel hexes that can fit 8mm axles, but I'm not having any luck; they all seem to have 6mm inner diameters instead. Does anyone know of a set that will fit 8mm axles?
fyrstormer is offline
Old 06-29-2020, 08:20 PM
ta_man's Avatar
Trader Rating: 161 (100%+)
What size "Across Flats" Hex are you looking for? 12MM? 14MM? 17MM?
ta_man is offline
Old 06-29-2020, 09:13 PM
fyrstormer's Avatar
The hex size doesn't actually matter as I'm going to be using them as collets to support a body on 8mm body posts. I did a similar thing with some Tekno RC hexes on the 6mm body posts on my HPI bullets several years ago. Much more durable than any other solution I've found.
I eventually figured out that 8mm axles are the standard size for 17mm hexes, so the problem is solved. I should've just measured a spare set of 17mm hexes to begin with.
gavsta72 likes this.
Old 06-30-2020, 12:22 AM
gavsta72's Avatar
Yeah 8mm axles are the standard size for 1/8 scale buggy, truggy, and truck 17mm hexes
gavsta72 is offline
