KYOSHO INFERNO MP10e
#271
https://www.bigsquidrc.com/hobbywing...brushless-esc/
#273
ok so I messed up and when i changed combo i selected the g3 2800kv instead of the 2400 will this motor be ok or should i change it the order is in but hasnt shipped yet
#275
From the looks the 2800kv is an open can as it’s an on road racing motor. How open, no idea, but I’d advise against muddy or dirty adventures and stick with the stock 14T as it will go like a rocket. With the hobbywing I would also recommend the HW OTA programmer assuming you got one that’s compatible.
#276
i actually did get this i also bought a heat gun to keep check on temps. what would be best for diff and shock oils as i did lots of research and was thinking just go standard
#277
For street ie asphalt then I’d look at this depending on your climate.
https://rsrc.biz/en/reno-s-setups/55...oya-setup.html
#278
Any opinion on brand of oil. we live in east coast so but will only run the cars 3 to 4x in winter. other then that we run them in summer.
#279
I'd use what ever your LHS has. I use Losi as it comes in a big bottle and good quality/price but I've used others and they're all ok. The viscosity aren't necessarily like for like (CST to CST) but for your use I wouldn't sweat it.
#280
matty a
is your wiring for speed control connected with connectors or is that wire soldered strait to ECS.
#281
Hey matty i went off that setup sheet and it had 30,000 for diff gear front and rear 50k for center. i just put this in front and sealed it up is supposed not be as free to spin like i need to put some muscle in it to spin it is this due to the oil being thick. i know mp9 i used 3000 in front and rear 5000 for center and it spins nice and freely just want to make sure this is normal
#283
Yes and no… you may have added too oil much and locked it up. There’s a grub screw on the diff case. Hold the diff so that’s facing up then unscrew it. If oil gushes out then too much oil, leave it and let out the pressure. If just a trickle it’s fine, remember to put the screw back in.. The diffs will be a little tight until things break in. 30k is very thick but the whole package will need a little time, a battery or two, to loosen up.
#284
hey thanks for the help so far i went with these batteries 2 of them the dont have a connection to do balance charge am i good to just do regular i tried to look it up cant find nothing except you should always balance charge
#285
protek lihv 9600mah 2-cell 7.6 130c
