Dynamite Dynp1001 won't accept throttle inputs keeps resetting.
Hi Guys,
Unfortunate 1st post but the title says it all, I have followed the Manual for programming the throttle responses and the esc just keeps resetting.
Video included.
Things I've tried
Unplugging battery
Changing battery
Changing batts in controller
Unplugging esc
Playing with throttle trim
Here is the video
https://streamable.com/e7xelv
Video included.
Things I've tried
Unplugging battery
Changing battery
Unplugging esc
Here is the video
Location: northern Indiana southern Michigan all depends on the day.
the esc is supposed to reboot, and then run. which makes me think the set button is stuck push in. id check this first. other wise i can only assume its broken but check with your local hobby shop or call horizon hobby as it may be a warranty issue, if its bran new. that is my gess at this point.
wow warranty on a item from what 2010 or 2013...how do you know this esc is still good?
ill revert my answer to the set-up button maybe stuck or the esc is just dead. and need a new one
what is the motor turns? this esc has a 13.5 limit..
Might be time for a new ESC there.
