Redcat Terremoto v2 steering problems. >
Old 04-08-2020, 12:49 PM
Default Redcat Terremoto v2 steering problems.
I have a redcat terremoto v2. When I turn it on the steering wheels instantly go all the way to the left. After they are stuck in that position they don't move when I try to steer them. First I replaced the steering servo and it did the same thing. It went to the left then didn't respond. So then I checked to make sure it wasn't the receiver by switching the throttle and steering wire. The throttle worked perfect being switched. So it's not the receiver. So my only guess is that's it's the controller. What do you guys think it is?
Kjanora10 is offline
Old 04-09-2020, 09:43 AM
Biz73's Avatar
Trader Rating: 18 (100%+)
Is the steering trim set all the way to one side?
Biz73 is offline
Old 04-09-2020, 11:11 AM
Mirkinator's Avatar
This or its possible the end points got messed up. Try to rebind your controller with all the dials to 0. Not sure if this is the radio you have but..
https://dealer.redcatracing.com//man...CENRMANUAL.pdf
Mirkinator is offline
Old 04-09-2020, 11:19 AM
No the steering trim is not set to one side.
Old 04-09-2020, 11:22 AM
It goes all the way to the left and then doesn't respond to the transmitter anymore. I tried it with 2 steering servos.
Old 04-09-2020, 03:45 PM
R/C Tech Elite Member
lowspark's Avatar
Disconnect the steering arm from the servo.
Turn on the car
Reconnect the steering arm centering the arms..
Note check first, with the steering arm disconnected, will the servo go left and right now using the radio?
lowspark is offline
