Backyard off-road track
Kicking around building a track in my backyard. Thinking of starting really simple by just cutting the grass real short once I come up with a design. Any of you ever try anything like this? Once I'm happy with the design I might rototill the grass out and add some jumps but just looking to get out running for now. All advice welcome. Thanks
Seems to a number of them recently.
I’m working on one.
Horizon hobby posted this
I’m working on one.
When I build track I like using your approach. I'll layout a design and then run on it without any obstacles. After running on it for a while I'll be ready to either change the layout or add obstacles. If your lanes are too narrow it's difficult to keep your speed up and you end up putting around the track. Here's my latest one. I'm already changing it up to make wider lanes.
Nice fellas my friend and my cousin have backyard dirt tracks and we put cheap carpet on the jumps so the rain doesn’t mess them up
Thinking about something kind of like this just to get started. Make sure it's fun considering the space limitations and such. Then look at maybe bringing in some dirt or rototilling out the grass. Then add some jumps. I'm a little surprised more people dont build tracks on really hilly terrain. Whether for personal use or a business. Back in my motocross days it was hugely more fun to ride and race on hilly tracks compared to relatively flat ones
I've never run on a "real" track so I'm not sure how wide the lanes should be. What do you think?
No need to apologize it's all good. What class of car do you run on it? How short do you cut it? Obviously any car could be run on grass but it seems to me anything with bigger wheels and more ground clearance will do better. I'm concerned it will be slow running and cooking Motors and ESC with high temperatures. One of my lawn mowers is an old one that I don't use. I think I could drill some new axle holes and get the blade almost to the ground. Or maybe a spacer above the blade to lower it. I think if I could cut the grass to less than an inch would be my best bet. As of now I only have two wheel drive buggies and Stadium trucks. Would be nice if I could run these with good results. If at some point I convert to dirt maybe I could run smaller cars. It seems obvious that a little car will make a track seem a lot bigger
Can you tell me what class of cars or trucks you ran on that? Did you have any problems with overheating Motors or ESC? How fast would you say your cars are relative to a smooth hard dirt track or clay. I know grass will be slower just wondering if it will be hugely slower. If that's one of those questions that is impossible to really answer I'll just start with an oval with my 10th scale stadium truck and take it from there
