Drive shaft install
So I got these great INTEGRY drive shafts- they have a set screw that holds the shaft onto the trans and axel stubs- all the videos I've seen the stubs have a hole through them where the set screw goes through- BUT my axel and trans stubs have no hole- can I just use set screws that will hold- OR do I have to drill some holes (with having a stroke- i'm pretty sure drilling may be out haha) ? or any other ideas? I am pretty sure this is a 90"s (?) style axial scorpion(?) no one has been able to ID it yet-
Not really sure I understand your question, do you have a picture you can post?
Kinda sounds like you need to grind a flat spot on the axle in order to give the set screw something to bite onto. |
Yeah that's what I did- I had a senior moment and was overthinking this- I got the set screws locked down and ready to take it for a spin- thanks-I just wish the output stubs(shafts) had holes where the set screw would go through sort of lke this from the trans
https://cimg1.ibsrv.net/gimg/www.rct...a0cde72c60.jpg |
