Losi 22 5.0 DC Transmission Problems >
Like Tree2Likes
  • 1 Post By bonzo915
  • 1 Post By dcerven94
Old 02-13-2020, 08:17 PM
Default Losi 22 5.0 DC Transmission Problems
So i have a brand new losi 5.0 buggy that when its on the ground the car will not move. The tires just inch along, and it sounds pretty bad. I have a hobbywing juststock 17.5 in it. I have adjusted the slipper and that isnt the problem. Im thinking its the ball diff, but i dont want to take it back apart unless i know thats the problem. Is the ball diff to tight or am i looking in the wrong place? Off the ground the cars wheels will spend almost normal, the sound still seems off like something is binding. Thanks for the help
24Racing is offline
Old 02-13-2020, 10:47 PM
Default Trans case screws
I would start by double checking to make sure that you used the 10mm screws in the correct spot when mounting the trans to the chassis and didn't accidentally use the 12mm screws in the middle set of transmission case holes. This is a common mistake and will deform the inside of the case pushing up into the diff gear.
fastman316 is offline
Old 02-13-2020, 11:11 PM
RazorRC's Avatar
post a video
RazorRC is offline
Old 02-14-2020, 03:59 AM
Hey 24. A good way to easily troubleshoot this to start by taking off your opinion from your motor. Once you have that off you can spin the tires and see the transmissions spur gear spin and then you can hold the spur gear and if you turn one tire forward the other should turn backwards. You can do the same on one of your other RT our cars to get an idea for how the transmission and differential should work and feel. That will at least tell you if you have a problem internally or not. One of the other common things that Iíve seen withHey 24. A good way to easily troubleshoot this to start by taking off your opinion from your motor. Once you have that off you can spin the tires and see the transmissions spur gear spin and then you can hold the spur gear and if you turn one tire forward the other should turn backwards. You can do the same on one of your other RT our cars to get an idea for how the transmission and differential should work and feel. That will at least tell you if you have a problem internally or not. One of the other common things that Iíve seen with First time Kipp builders if they forget the pin in the axle that engages in the drive hacks and that can spin and sound bad too LOL hope that helps, and like others said above, post a link to a video and that would help out a lot
Johnoly99 is offline
Old 02-14-2020, 04:53 AM
bonzo915's Avatar
Check the 10 mm vs 12 mm screws going into the bottom of the chasis if they are wrong it will bind the tranny
TurnNBurn likes this.
bonzo915 is offline
Old 02-14-2020, 07:27 AM
Mason's Avatar
the things you need to look at: motor wires are wired up in the correct order. gear mesh and or any debris in there. the various drive shaft/axle pins, slipper (as you already noted), ball diff (specifically if you didn't compress the spring on initial build), proper length screws as others noted. wouldn't hurt to try a different sensor wire as well.
Mason is offline
Old 02-14-2020, 09:49 AM
Thanks, i will check to make sure the correct length of screws are in the right spots. If that doesnt fix it i will post of video of what the car is doing
24Racing is offline
Old 02-14-2020, 09:54 AM
TurnNBurn's Avatar
Yep, Iíve read this being an issue before, and of course, the manualís got the Exclamation symbols to point it out... I must have checked 3 or 4 times myself before screwing those in, lol.
TurnNBurn is offline
Old 02-14-2020, 06:53 PM
Took everything in the rear end apart, double checked all screws and put it back together and it sounds much better. I had to have put some longer screws in the wrong places during the build not paying attention. What is the best way to adjust the slipper on these? The car seems to move slowly at first then takes off at full speed, i have already tighten the slipper down some.
24Racing is offline
Old 02-15-2020, 08:43 AM
dcerven94 is offline
Old 02-15-2020, 08:48 AM
Would like to emphasize the importance of setting the diff before the slipper. once the diff spins/slips permanent damage occurs.
RazorRC likes this.
