Old 09-04-2001, 10:46 PM   #31
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I run a FT B3 for 2WD Mod off-road, and a FT TC3 for carpet Sedan (Stock and Modified)
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 09-05-2001, 05:40 PM   #32
B3boy's Avatar
Send a message via AIM to B3boy
I got a FT GT with a OS CV-X
it is pretty new and goes fast
B3boy is offline   Reply With Quote
Old 09-13-2001, 01:12 PM   #33
ovalnator's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to ovalnator
Originally posted by Taz_S
It should work but finding the right tires maybe the problem.
Finding tires wasnt a problem; I took the wheel hexes off and used Custom Works Foams. worked like a charm
ovalnator is offline   Reply With Quote
Old 09-13-2001, 01:12 PM   #34
T3master where do you run???
RUBBERSALWAYSUP is offline   Reply With Quote
Old 09-15-2001, 10:39 AM   #35
I run at TRCR.
T3Master is offline   Reply With Quote
Old 09-27-2001, 05:07 PM   #36
ovalnator's Avatar
Well, now Im working on a conversion to make my TC3 an offroad buggy, and wider than the rally version
Old 09-27-2001, 08:29 PM   #37
Regional Moderator
disaster999's Avatar
hey...a new off road from tamiya
disaster999 is offline   Reply With Quote
Old 10-04-2001, 03:34 PM   #38
Regional Moderator
Darkseid's Avatar
Hey guys, I'm going to be running a buddy's B3 in offroad this season. I don't know anything about AE stuff, so I was looking for a quick answer.
He had an 81 tooth spur on the car, whats a good pinion to go with it when running a stock motor? If it matters, I'll be using a P2Kpro.
I also have extra 84, 87, 89 tooth spurs if that will help with your recomendations.
Thanks for any help.
TLR 22...Tamiya F104...
Old 10-09-2001, 12:50 PM   #39
Send a message via ICQ to randalee Send a message via AIM to randalee
Team Associated has a full graph on their web site of what is recommended...
This is where to start with the B3:
24 deg. ROAR stock motor 24 pinion 81 spur 8.1:1 ratio
DS Spec motor (kit motor) 23 pinion 81 spur 8.45:1 ratio
36 deg. stock motor 20 pinion 81 spur 9.72:1 ratio
14 turn modified motor 22 pinion 81 spur 8.83:1 ratio
13 turn modified motor 21 pinion 81 spur 9.25:1 ratio
12 turn modified motor 20 pinion 81 spur 9.72:1 ratio
11 turn modified motor 19 pinion 81 spur 10.23:1 ratio
10 turn modified motor 18 pinion 81 spur 10.8:1 ratio
I would try out a 24 -- you may be able to go a tooth or two bigger with that P2k, (possibly a 25 or 26). However, I don't have a B3 so I couldn't tell you for sure. I have run a T3.
Randy Clements
Sandy, UT
randalee is offline   Reply With Quote
Old 10-09-2001, 08:53 PM   #40
that is not a new buggy it is a re-release of a buggy that tamiya produced in the early 90's still is pretty cool though
bladerunner is offline   Reply With Quote
Old 10-10-2001, 01:08 AM   #41
M 5
It is a new buggy, just the same name.
Would you say ta04 is a re-release of ta03?
M 5 is offline   Reply With Quote
Old 10-10-2001, 10:12 AM   #42
Regional Moderator
Darkseid's Avatar
Thanks randalee, that will be enough info to get me to the track, then I'll hook up with some of the people who run it and see what the best gearing for our track is.
Old 10-10-2001, 06:18 PM   #43
dude it is the same buggy even the tires are tha same if you want I will try and scan in an old magazine article to prove it I know what I am talking about trust me
Old 10-10-2001, 10:55 PM   #44
That Tamiya buggy looks like the old Astute, I think that is what it was called! Can't tell for sure if it is identical, but it definately looks like it! Wonder what urged Tamiya to introduce a new high end buggy?
WailinOnYa is offline   Reply With Quote
Old 12-31-2004, 11:02 PM   #45
trx1's Avatar
Send a message via Yahoo to trx1
I have a RTR t3, nice truck, but it needs a battery hold down..
trx1 is offline   Reply With Quote
Md,va,pa,dc Offroad Forum Brian Miskolczi Electric Off-Road 1184 04-20-2013 05:50 AM
Queensland Offroad R/C Forum. Kanzai Web Links 2 08-31-2007 04:43 PM
Split Up Nitro/Electric Offroad Forum?? cpatel529 R/C Tech Site Forum 10 05-04-2007 09:53 PM
Offroad Forum Matt M. Wisconsin & Illinois Racing 55 10-16-2001 04:33 PM
