Tekno Eb48 2.0 EBuggy
#706
Nope thats about right. I just built a fresh kit this week. I think the slop is by design; but you could add 1mm shim in there if you wanted to take out a little play. I think once you run it, and dirt gets up all in there, and things move about, it won't feel as loose...
I also put extra shims on the front arms which are not included in the kit to take out that slop... but every car I've owned will get slop everywhere, and that can be a good thing to help make a car a little more forgiving in the corners... I feel that a super tight car will tend to be more twitchy.
I found some extra slop on the rear pins that need a spacer too:
#707
#708
I don't know if that's what I want. I'm just building the car to manual spec. This is my first true competition buggy. The front arms have almost 2mm of back and forth play after assembled. It seems like alot and I've triple checked that I've done everything right. It seems like alot of play in the front arms....more than the back for sure. I know you want everything moving free but with the least amount of play from my understanding. I've always had 1/8 rtr vehicles and chalked up the slop in them as poor quality and bad assembly. I'm kinda confused...and worried I'm not putting this car together right, like there is something I'm doing wrong throughout the entire build. Thank you to everyone for helping with the advice.
#709
I would advise against taking out all of the play in the car, and especially advise against using fuel tubing. You want the car to be as free as possible. We've tested back to back to back several times, a car with the extra play is better than one with little to no play every time.
#710
Almost done....just need the shocks and electronics to finish up. I needed to stop over thinking everything and just build it. After I started doing that I was less stressed and things moved along more smoothly. It's so pretty, like a work of art. Almost afraid to race it because I suck at driving and it is going to get tortured tested for sure. Again I want to thank everyone for their help and advice.
#711
#712
This why I sold my sons 8ight after last season and got another 2.0. On Monday we were out at the track and as my buddy and I watched my 9 year old chuck his 2.0 into a pipe we both went... "it's ok it's a Tekno".
#713
Ok guys and gals....what is the deal with the shock collars???? Why in the hell are they so hard to put on and turn. Does anyone have a tip or easier way to get those little buggers on??? My fingers are soo sore just after the front ones and I still need the rear ones to do. I oiled up the orings but that did little to help with turning them once they are on the shock bodies.
#714
#715
I wonder why Tekno didn't give us a measurement from the top of the shock collar to the lip right under the shock cap to give us stock ride height. That way you wouldn't be struggling with the shock collars if it was screwed on too much or too little. I don't think I will be able to adjust for ride height after the shocks are put on the car. They are just too hard to turn. I have to hold the shock body with a wrench just to turn the shock collar.
#716
Another reason to thread them to the top is so that you can mark the collars. I thread mine all the way up and then dremel a groove aligned with the shock cap. This way I can accurately count the number of turns I give the collar when making ride height adjustments.
#717
run the collars on reverse for like 3-5 threads oiled, then remove and put them on the right way, way smoother.
#718
Anyone try the new Protek shorty in the 2.0?
#720
3 fresh new sets of premounted wheels and tires. In both red and blue compounds for when I finish my build. Going to do the rear shocks tonight. Taking my time with the build. Almost done!!!!
