AE B6.2D / B6.2 Thread
#2746
Thanks guys...........
#2748
Anyone installed B6.3 towers on their 6.2 / 6.2D?
Looking at retaining a car for wet (layback) and it'll either be my current 6.1 (converted to 6.2D) or my 6.3. Currently my 6.1/2 is the layback car.
#2749
The only thing thats hard is either drilling the chassis for the .3 mount or the expensive part of buying a .3 chassis and servo mount. My .2 just has a stack of washers there.
#2750
Yes I have basically all the .3 parts on my .2 other than the wide pivot. The towers are the easiest thing to swap probably, and the front tower is really nice with the new cover.
#2751
#2752
I've never personally seen plastic gears for the B6 gear diff. you can just run 2 planet gears to save a bunch of weight. titanium screws will also save a little weight. Zombierace rc titanium screw set for Team Associated B6 gear diff
#2755
#2756
The B6.1/2 towers have the same shock positions but there are short and tall towers. The .3 and .4 have the same tower, but it eliminates the outer most hole on the back tower and has them much closer together. The fronts are closer together on the .3 and .4 but eliminate the most inner hole. They are not commonly used, but in low grip situations like Roger pointed out can be useful on the back tower. No idea if the inner front hole is ever used. But I dont run on carpet/turf especially in crazy conditions.
#2757
You can get the sweep by trimming 2mm off the B6.2 arms but the stiffness of the arm means it still doesn't generate enough grip on slick wet astro surfaces.
#2759
#2760
Set up advice for grass tracks required. I have a b6.2 with willspeed front end and 75mm arms turn in on grass is great but any throttle input will make it swap ends which is ruining my abiltiy to drive consistantly.
I used this setup to start with
https://site.petitrc.com/setup/assoc...nster20200622/
I am buying a 6.2d chassis and 73mm arms to cure some of the issue. would I be best looking at a setup
like this to get started
https://site.petitrc.com/setup/assoc...haven20210530/
regards
regards
