Old 03-13-2006, 05:20 PM   #1
Johnathan's Avatar
Default Tires, Tires, Tires!!!
i have a electric Rustler, which i have dremeled and put a brushless in, and it shredds the teeth off of my tires faster than i can make money! actually, i go through the a pair of tires in a week or so, but its inconvinient to buy new ones at 20$ a pair...the tires, are proline off road tires, and they seem softer than what i would like. here are my questions:
1 - are there "very hard" off road tires for under 25$?
2 - is there a way to harden tires with chemicals or heat?
3 - should i downgrade my motor?
all help is appreciated!!!
Johnathan is offline   Reply With Quote
Old 03-13-2006, 05:47 PM   #2
That0neguy's Avatar
Dont run on street.
Make sure the dirt you run on is wet.
Hello.0
That0neguy is offline   Reply With Quote
Old 03-13-2006, 06:04 PM   #3
Johnathan's Avatar
OH!!! WET dirt! im so stupid!!! thats a good idea. i have a seperate set of tires for onroad use.
is there a way to harden tires?
Old 03-13-2006, 07:11 PM   #4
There isn't away to harder tires, if buying from Pro-line get M2 compound, Team Losi get Silver compound.Also, use a step-pin tire, as it is the biggest pin.
the dirt is offline   Reply With Quote
Old 03-13-2006, 07:20 PM   #5
WheelNut's Avatar
Send a message via MSN to WheelNut
Any of the tires listed under all terrain here will last you pretty much ever as long as you don't take them on asphalt. Get some speed paws for grass, they are so hard they don't even need foams, plus they are really cheap.
http://www.pro-lineracing.com/prolin...uck_tires.html
•Brad Comis
WheelNut is offline   Reply With Quote
Old 03-13-2006, 07:20 PM   #6
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
The more meat on a tire...the longer it will wear
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 03-13-2006, 07:22 PM   #7
That0neguy's Avatar
Yea dry hard dirt will eat your tires up 10X faster then when wet.When I go to the track I run everyone off the track so I can water.Not just for better traction but to keep my tire bill down too!
Also hardening is not the way to go.Get them rubbery and elastic as possible.Use WD-40 or buggy grip.
Thing about it.Those crappy earsers on cheap pencils that just smear rather then earase last for ever.There rubbery and elastic!
The good pink ones ware away real fast.There hard and will break if you bend them.
Good luck.
Hello.0
Old 03-14-2006, 09:17 AM   #8
Johnathan's Avatar
thanks for the help, my backyard is dead from what i will call a drought. the ground is hard dirt, probably the reason my tires shred up. i think i will water the backyard when i plan to bash/race my friends. thanks!
Old 03-14-2006, 09:33 AM   #9
Trader Rating: 26 (96%+)
If you want to run in the street then use a the same pair of tires over and over. Bald worn down tires will work fine. I have been using the same worn out tires to bash around for the past year. When I go to the track I can now afford to have fresh tires on my car.
party_wagon is offline   Reply With Quote
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
