TLR 22X-4, 22X-4 Elite Thread
#1366
Domed caps are a must have. the cars do everything better with them
#1367
Hi all,
yesterday, I tried the 22x-4 for the first time. I had two problems:
1) does anyone also had problems by using the composite servo horn?
Ich used the horn as pointed out in the manual for my Sanwa servo and recognized that the servo horn is able to move under load. The screw was tight and the servo isn’t moving - it’s just the horn.
I don’t want to use the alu version, because the plastic horn will save my servo in case of a huge impact.
2) after a while one of the front wheel nuts came off. I used the original nuts with Schumacher wheels. Does anybody else had this problem too?
Thanks!
Thanks!
#1368
Hi all,
Thanks!
Thanks!
All my buddies running TLR cars seem to use TLR wheels and have not had any issues yet. In general, I can highly recommend the 1up racing wheel nuts #80501. I bought mine at Tonisport, but they are currently out of stock.
#1369
#1370
I run Schumacher wheels and tires on carpet, and have not experienced the wheel nuts coming loose.
#1371
TLRacing
Hi all,
Thanks!
Thanks!
For the wheel nuts, it shouldn't be an issue, not something we've seen much of. Usually, they just aren't tightened tight enough.
#1374
Hey guys, just got a 22X-4 as my first ever wheeler. New to gear diffs and was wondering what the maintenance looks like on them. How often are you changing fluids or doing full rebuilds?
#1375
Running factory setup, what droop length is optimal for off-road tracks. I cannot locate any information as to what the recommended setup is. Track- high grip, few moderately long jumps. several technical and high speed sections.
Thanks.
Thanks.
#1376
shock conversion
Hi i was just wondering does anyone run the 3.5mm shock conversion, and if so is it any better than the kit and what's the end result of using them?
thanks
thanks
#1377
#1378
#1379
There’s a G3 shock comparison image some pages back with a detailed breakdown of the two - the question gets asked from time to time.
#1380
All things being equal (piston, oil, spring, etc.), the 3.5’s have more pack and feel more “plush” than the 3.0’s. In contrast, the 3.0’s are more reactive, and while they land a little harder than the 3.5’s, they rebound/recover much faster.
thanks for the reply
