GS STORM CL-1 THREAD
any body have any experience with one .
I don't have personal experience, but a guy at the track has one. The first week he put it on the track he won the a main. And has continued to do so since then.
Marty Korn finished 5th at The Dirt with a mostly stock ride. Not bad for the big pro race of the year.
I have two practice sessions on mine and will be running the first club race this weekend if it doesn't rain. Marty's set up is a very good baseline for the car. The CL-1 is very stable and tracks well. So far so good.
the CL1 is my next ride hands down
Guys this is my current outdoor set up I have been running.
GS Storm CL-1 (Brandon Powell)
FRONT END.................................REAR END
Shock Oil : 50wt (GS).................Shock Oil : 35wt (GS)
Piston : 1.5 mm........................Piston : 1.5 mm
Spring : Blue GS.......................Spring : Blue GS
Pre-Load : 6 mm.......................Pre-Load : 4 mm
SHock Location......................... SHock Location
Upper : 3rd hole, bottom row........Upper : 3rd hole, bottom row
Lower : Outer hole......................Lower : Middle Hole
Caster : 3mm front, 1mm rear........LINKAGE
...............................................Tow er : #3 hole
Front Roll Center: Lower hoel.........Hub : #2 hole
...............................................Hub Loc: 2mm front, 3mm rear
Servo Saver: Medium...................Wing: Upper hole
Ackerman : Middle hole
Anti Dive : -1 degree...................Anti Squat : 2 degree
Camber : -1.5 degree................Camber : 2 degree
Toe : Out, 1 degree...................Toe : 3 deg. block,1 deg. on hub
Swaybar : 2.3mm , stops flush.....Swaybar: 2.8mm,stops at 3mm
Droop : 19 mm...........................Droop : 17 mm
Diff Oil : 7000wt (GS).............................Diff Oil: 3000wt (GS)
x
Center : 10,000wt (GS)..................Brake: 30% fr. , 70% rr.
Motor: RB Mods P5x
Clutch: Aluminum, 1.0 springs
Clutch Bell: 13 t................................Fuel: Maxy's 30%
x
Motor: RB Mods P5x
anyone have any trips for getting the fluids in the diffs filled right? On mine, I built it...filled them. Ran the car. Took it apart again and the diffs were only about 1/4 the way full? I figured it was due to the smaller gears not letting the oil get under them?
Yea it didnt leak any around the seal or the gasket. I think I just need to realize its gonna take more than 2 minutes I will take a little more time on them next time and see if I get better results.
Yah..I just need to make sure to fill them better next time. How are you liking your car these days Brandon? Im gettin my geared up hopefully soon. Ive got a few prosecs and sp2's on my radar I would love to derail..haha
Runnin,
You better do alot more homework if you are thinking about passing my Pro Spec!
Better yet I will give you a really good lesson on the track this year.
If a prospec's gas tank was any taller you would need to cut the body and the spur gear is way too big a 46 not a 44 like the cl1.
Ok I'm just playing the prospec is a dam good car too!
Here's the final buggy line up at Silver State in Vegas this afternoon.
Paul Coleman won the B Main, Cavalieri, Maifield and JR Mitch have bumped to the Amain
Starting line up - Amain (provisional for bottom 4)
1. Scott Hughes - Mugen/OS
2. Atsushi Hara - Hot Bodies/OS
3. Mark Pavidis - Kyosho/OS
4. Taylor James - Jammin/OS
5. Marty Korn - GS/Collari
6. Greg Degani - HoBao/Picco
7. Richi Gomez - Sidorf/Novarossi
8. Adam Drake - Jammin/Sirio
9. Jeremy Kortz - HoBao/Collari
10. Jared Tebo - O'Donnell/O'Donnell
11. Chad Bradley - Jammin/OS
12. Paul Coleman - HoBao
13. Ryan Cavalieri - Kyosho/Orion
14. Ryan Maifield - TTR/LRP
15. JR Mitch - TTR
Cavalieri and Maifield have both bumped up to the B Main from the I and G mains respectfully.
15. JR Mitch - TTR
What happened to RC and Mayfield?
