Question about pinion and spur >
Like Tree2Likes
  • 2 Post By Davidka
Old 11-30-2019, 08:42 AM
Default Question about pinion and spur
Do you guys recommend using like a white lithium grease for the gears maybe a light coating or Do you use something else or nothing at all ?
rrb1399 is offline
Old 11-30-2019, 08:56 AM
Davidka's Avatar
Trader Rating: 84 (100%+)
Pinion & spur run dry. Internal gears can use a touch of grease, but you don’t want to use it on anything that isn’t sealed or all metallic because it’ll attract dust and accelerate wear.
Shnoo and rrb1399 like this.
Davidka is offline
Old 11-30-2019, 07:35 PM
Graphite HB #3
Juglenaut is offline
Old 11-30-2019, 07:49 PM
There are graphite spray on lubes, powders, sticks.. I only use it on new metal spurs and pinions and reapply during rebuilds, I don’t constantly apply. I also use dry lubes on rod ends, pivot balls, and hinge pins. I have considered going dry on cv drives but have not.
Old 12-01-2019, 02:13 PM
Always dry on pinion and spur, Associated silicone in the gearbox.
K.Kincaid is offline
Old Yesterday, 06:03 PM
I have a pinion set screw that seems to not fit the wrench slightly. are there different size set screws for this application? is there a better allen wrench to have for this? thanks in advance?
vegas7o2 is offline
Old Yesterday, 06:04 PM
also is there anyway to tell a t6.1 spur between a b6.1 spur I was planning on switching the b6.1 and I wanted to be sure I wasn't putting the wrong one on? I googled MM but doesn't seem to show that so any help would be appreciated here as well !! THANK YOU!
vegas7o2 is offline
Old Today, 07:27 AM
Pinion set screws generally use a 1/16 sae or 1.5mm metric wrench. Make sure the tip on your wrench is not rounded.
