Willspeed RF2 B6.1 Conversion kit build >
Like Tree110Likes
Old 10-25-2019, 04:28 AM
  #31
I had a question on the wheel base, Iím running B64 rear arms but looking at the associated website the B6.1 in stock form has a wheelbase of 277mm-279mm
E-Mann likes this.
Headling is offline
Old 10-25-2019, 04:54 AM
  #32
Here are the battery hold downs after the rit dye bath for an hour, looks loads better 😎
Headling is offline
Old 10-25-2019, 07:43 AM
  #33
The shocks were leaning back a little on the rear so fitted the longer shock bushings, looks loads better now
Headling is offline
Old 10-25-2019, 12:33 PM
  #34
I had a question on the weight of the car, here is Willís xb2 with a full size servo and full size shorty lipo in it
and stock xb2 parts (no titanium etc)
Iíll weigh my 6.1 version once itís finished
Headling is offline
Old 10-25-2019, 02:08 PM
  #35
Wired up, excuse the electrics and lipo, Iíll replace this with a antenna less Rx and a nice low profile servo
Iíll do a one can wonder shell and get a new one custom painted in my colours
Headling is offline
Old 10-25-2019, 02:09 PM
  #36
Headling is offline
Old 10-26-2019, 02:14 PM
  #37
The bodyís trimmed out and this one will have a one can wonder paint job whilst I get a proper shell customer painted in my colours
Headling is offline
Old 10-27-2019, 02:44 PM
  #38
What's the weight distribution f/r?
AntH3001 is offline
Old 10-28-2019, 04:03 AM
  #39
I am not sure tbh and I don't own any corner weight scales
Headling is offline
Old 10-28-2019, 04:12 AM
  #40
I had a question of this conversion can be build from a B6 and the answer it yes!
I have done this and these are the parts I used:
B6.1 slipper innner and outer
B6.1 slipper spring
B6.1 top shaft
Rear front C block - I used a jconcepts one
B6.1 spur gear
The front end just bolts on and you'll need the slipper parts as above and the B6 diff is a perfect fit in the willspeed gearbox
JCG1 likes this.
Headling is offline
Old 10-28-2019, 07:13 AM
  #41
A quick factory white paint job and she is ready to hit the track this Sunday!
Iíll be heading to my local club on EOS carpet, Iíll report back with my findings
Headling is offline
Old 10-28-2019, 07:19 AM
  #42
Headling is offline
Old 10-28-2019, 12:54 PM
  #43
I had a question on the weight of the chassis compared to the stock B6.1 chassis and Iím pleased to report back itís lighter than the stock chassis
Standard B6.1 chassis with side rails is 240g
Willspeed B6 chassis 190g 😀
As per picture of Wills xb2 RF2 itís under 1500g with a full size lipo and servo, so with a low profile servo and lipo itíll be under weight and good to tune for the stock racer
D1360 likes this.
Headling is offline
Old 10-29-2019, 05:31 AM
  #44
I wanted to make up a low profile battery mount for the RF2
You can see the part numbers below and should be easy to get hold of
The carbon tabs are from a Mi7 Schumacher touring car but you can buy the exotek tabs on there own
Headling is offline
Old 10-29-2019, 05:33 AM
  #45
stevenkelby likes this.
Headling is offline
