Velocity VT64 1/10 4wd Truggy >
Old 09-17-2019, 06:00 PM
cameronspruill's Avatar
Trader Rating: 21 (100%+)
Unhappy Velocity VT64 1/10 4wd Truggy
I'm having gearing issues. I'm running a 10.5 motor 81t spur 18t pinion and a fan but my esc keeps shutting off(thermaling) around 5 mins in. Everything is free there is no binding anywhere. Can anyone help me with this? Suggestions?
cameronspruill is offline
Old 09-18-2019, 12:47 PM
Tech Legend
Cain's Avatar
Trader Rating: 259 (100%+)
So the ESC is thermalling but the motor temps are fine?
What electronics are you running specifically?
Example:
- hobbywing XR10 Pro
- Hobbywing 10.5 V10 motor, timing set at 30 degrees
- etc ...
- Are you running boost, turbo, etc on the ESC, if so what settings?
Where are you topping out down the longest straight on your track?
Cain is offline
Old 09-18-2019, 01:23 PM
sea1swk's Avatar
No Velocity VT64 for me, until there is a VT74! But in my et410, I had issues until I went with a 4 Pole speed control. I'm running the Tekin RX8, but I would think the Hobbywing Xerun SCT Pro would be fine. The 4 Pole speed controls can also run the 2 pole motors. I personally have a hard time driving mine with a 540 can, Tekin 4600. It is stupid crazy fast. I went to a 6.5 turn Maclan V2 motor, and the speed is great but not to much. But I find the 6.5 turn motors get to about 160 degrees, with a fan, and a bit to hot for my liking. Side note, I'm trying to find a 4 pole motor that is more like a 6.5 or 7.5 turn 2 pole motor. I heard a rumor you can run a Tekno et410 32 pitch Spur/center diff in the Associated. My truggy eats 64 pitch spur gears.
sea1swk is offline
Old 09-18-2019, 04:00 PM
Example:
- etc ...
I'm running a Tekin rs esc 10.5 reedy motor the motor is getting to hot and the esc shuts off around 5 mins there is no binding anywhere the esc is in blinky so there is no boost or anything so we can't figure out why its doing this.
Old 09-18-2019, 04:14 PM
Tech Legend
Cain's Avatar
If I am reading this right you are just using a Tekin RS ESC, not an RSX or anything? I would say thats probably your problem. On my Yokomo YZ4SFT conversion I use the RSX Pro with a 6.5T motor no issues. You may want to look into that.
Cain is offline
Old 09-18-2019, 04:17 PM
The Tekin RS has a turn limit of 13.5.
Funkydrummer1 is offline
Old 09-18-2019, 06:30 PM
The RS has a limit of 8.5, the RS Spec is 13.5 but it doesn't have any heatsink so a 10.5 in the 4wd truggy might just be too much for it.
Di_spencer is online now
Old 09-18-2019, 06:45 PM
Yeah its just tekin rs not the spec one.So if I mounted a fan on the esc that would help you think?
Old 09-18-2019, 07:15 PM
Yep. Your right. 13.5 for spec. I had it as when he said blinky I was thinking the spec.
well, guys at my track and I as well run an 8 scale esc in 10.5 truggy.
I run the Tekin rx8.
Old 09-19-2019, 05:03 AM
hmm ok thank you
Old 09-19-2019, 07:24 AM
Tech Legend
Cain's Avatar
hmm ok thank you
Just an FYI, in a pinch I ran the RS Pro Black Edition in my truggy with a 10.5 in the early spring, it was cooler temps indoors so no heat issues and it worked great.
I would say though at a minimum I would get an RSX ESC to run. I htink that will give you what you want.
Cain is offline
Old 09-19-2019, 06:49 PM
ok thank you
