17.5 b6.1 motor help >
Old 07-20-2019, 07:45 PM
Default 17.5 b6.1 motor help
Currently have a reedy s+ plus and looking for something a little more snappy . My current timing on it is 36* with a 27/72 gearing . I am thinking about picking up a revtech 17.5 motor with the tep1119 rotor but donít know what timing and gearing to run. Any advice ? Thanks
Redheadrcguy is offline
Old 07-20-2019, 08:53 PM
Any help appreciated
Old 07-22-2019, 10:36 AM
Trader Rating: 62 (100%+)
XFactor 17.5 gearing should be good to start at 72/27. However, you can go shorter in gearing like 25 to be safe. These motors rev.
Leave timing where they set it. Somewhere between 35-58 degrees.
I currently run lower timing on the can when the air temp is high. 35 degrees.
In an indoor setting with 75 degree air temps I run around 45 on the can.
The Xfactors have a wide range of timing they can run.
Antimullet is offline
Old 07-22-2019, 11:17 AM
the rc guy's Avatar
Red whats your motor temps now?. you can add some timing and a few more teeth on pinion.. just keep temps below 165F
the rc guy is offline
Old 07-22-2019, 11:37 AM
I was running a V21 Wurks, tuned by Rotor Ron with his hop ups (Aluminum Screws). I ran 2 teeth under the setup book, indoor clay. Felt I was as fast as any.
sea1swk is offline
