Final Drive Ratio
Old 07-11-2019, 06:58 PM
Default Final Drive Ratio
Do most all the 1/8 Buggies have the same or very close to the same final drive ratio? The reason I ask is to compare motor and pinion choices. Do any brands run a different pinion gear count then another typically?
RCJamesJ is offline
Old 07-11-2019, 07:50 PM
Trader Rating: 20 (100%+)
AE and Mugen are the same or very close. Tekno is different. HB used to be quite a bit different, but not sure about the current car. Kyoshso is close to the AE and Mugen. Not sure what TLR has.
MX304 is offline
Old 07-11-2019, 08:01 PM
8ight e 4.0 is 9.28:1 if I did my math right lol on a 16/45 pinion/spur. 3.30 gear box ratio.
Front overdrive kit is 3.23:1
According to this I am at 9.90:1
Juglenaut is offline
Old 07-11-2019, 08:11 PM
Billy Kelly's Avatar
Billy Kelly is offline
Old 07-11-2019, 08:17 PM
Buy me one lol!!
Old 07-12-2019, 06:13 AM
Trader Rating: 31 (97%+)
Tekno is also different depending on which version you are running, some folks have taken advantage of this as a feature to change the IDR between the front and rear diffs as an "overdrive" to get the front the pull around faster.
billdelong is offline
