2wd 1/10 esc & motor >
Old 05-11-2019, 05:26 PM
Default 2wd 1/10 esc & motor
Building a 2wd rc10 b6.1 factory lite for stock racing, what Tekin esc and motor should I run. I have a Tekin spec 3 esc and spec 3 17.5 motor for my 2wd spec buggy
RClos17 is offline
Old 05-11-2019, 05:49 PM
I think Tekin considers their RSX Pro to be their premiere model for Mod. (Although the RS Pro BE does list itself as handling up to 2.5T 2 pole brushless).
jon003 is offline
Old 05-11-2019, 06:07 PM
Ok so RSX pro and what motor tho a 17.5 spec gem 3 motor ?
RClos17 is offline
Old 05-11-2019, 07:17 PM
suzukipro's Avatar
Trader Rating: 31 (100%+)
If it were my money I'd buy the TEKIN RS PRO or the RS Gen 3for running 17.5T instead of the RSX PRO (the RSX PRO is designed for mod motors more so than 17.5, but it will certainly work).
The Motiv MC3 motor is outstanding from my experience, or the Tekin Spec R is also decent if you want to stick with Tekin.
suzukipro is offline
Old 05-11-2019, 08:14 PM
yes so no budget , so the rs pro and a Tekin spec r 17.5 motor I was on Tekin site and they recommended the rs pro for drag cars and they suggested the rsx pro for buggy what you guys think
RClos17 is offline
Old 05-11-2019, 09:15 PM
RC*PHREAK's Avatar
Trader Rating: 129 (100%+)
if you're running mod, then i'd go RSX and a 10.5. that will be PLENTY for all but the most skilled 2wd buggy drivers.
RC*PHREAK is offline
Old 05-11-2019, 10:38 PM
suzukipro's Avatar
The RS PRO is the their top of the line ESC for stock 17.5T applications and it weighs less than the RSX PRO. Both are excellent ESC's though!
Old 05-12-2019, 03:12 PM
So you said Mod in your first post, but now you're talking 17.5 Did you mean Spec? If Spec, I'd get the RS Pro BE
jon003 is offline
Old 05-12-2019, 05:19 PM
Building a 2wd rc10 b6.1 factory lite for mod racing, what Tekin esc and motor should I run. I have a Tekin spec 3 esc and spec 3 17.5 motor for my 2wd spec buggy
Check at your local track..the FL version is built for stock racing. Using a mod motor will be pushing it but it will work.
dowj28 is online now
Old 05-12-2019, 06:58 PM
Oh ok so I am gonna order a new 6.1 limited edition , what Tekin system should I run the RS Pro or the RSX with a spec 17.5 motor ? At my indoor track I cant keep up with the Mod guys so I am gonna stay stock . What do you guys think is the best Tekin setup
RClos17 is offline
Old 05-12-2019, 06:59 PM
yes I meant spec I was thinking of building mod but I canít keep up with the mod guys at all yet . So I am looking to build a spec buggy what Tekin system do you suggest ?
RClos17 is offline
Old 05-13-2019, 12:14 PM
I'm running 4WD, 13.5 Spec-R and an RS Pro BE for ESC.
You should do just fine with a 17.5 and RS Pro BE as well.
jon003 is offline
