Old 03-02-2006, 09:46 PM   #1
Send a message via AIM to oMONSTERo Send a message via Yahoo to oMONSTERo
Default Transmitter wont center?
Heres what we have: a T3 with an ACE R/C Jaguar T2P TX and S1903 MG Servo. It has a Thunder Tiger RX. We noticed the truck would not track straight, so I started checkin it out. Long story, short, even out of the truck the servo will not center. If you turn left and release, it will stay left slightly, and vise versa. Put MY Futaba servo in the Jaguar equipt truck, same results. Put ACE servo in MY Futaba equipt truck, it works fine. Cant see any other culprit except the Jag TX.
Is there maybe some adjustment I can make?
Can I swap the crystals from the Jag, over to a Hitec Lynx we have, to see if it really is the Jaguar?
Man, it seems like one thing after another......
oMONSTERo is offline   Reply With Quote
Old 03-04-2006, 10:53 AM   #2
sport10's Avatar
First off your test has not eliminated the Thunder Tiger RX either. Also what frequency are you running on both radios? If they are both on the same band then it might be possible. If they are on seperate bands like 27 Mhz and 75 Mhz swapping crystals will not work.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 03-04-2006, 06:03 PM   #3
Default Couldnt wait, hehe
Well, I got impatient and had to try something. So, seeing that, as you say, they were both AM 27 mhz (27.045 + 27.145 What a coinckidink, huh?), I just swapped crystals between the ACE and the Hitec, and everything works GREAT!!
Now, what do I do about the ACE? Since the Hitec came with the GT we bought, we need the ACE fixed so we can get the GT running (with out having to swap back and forth).
Old 03-06-2006, 06:11 AM   #4
Default Come on guys
Who's the TX tech expert in here?
Old 03-06-2006, 08:42 AM   #5
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
All 27MHz AM x'tals are the same.(no shift difference)
Go to the Radio Shack and get a full set of X-Mod x'tals for $15
Tres is offline   Reply With Quote
Old 03-06-2006, 03:57 PM   #6
sport10's Avatar
Considering how little that radio is worth I would just look into getting another radio instead of trying to get it fixed. It's a good time to upgrade to a FM computer radio version if you ever wanted to.
Associated B44
Associated B6
Associated TC7.1
Old 03-08-2006, 06:44 AM   #7
I already have a set of XMODS crystals, but, having crystals was never a problem.
We REALLY dont have the money to upgrade, at this point. With our level of skills, and lack of local participation, it probably wouldnt "help" a whole lot anyway.
How much is an ACE, or any other TX of comparable quality that will work in our situation, worth? I dont think Ive seen any for less than 70-80 bucks.
Old 03-08-2006, 02:08 PM   #8
Check www.towerhobbies.com you can get a Futaba for $43.00 w/ reciever, crystals and a servo, or just a transmitter for $30.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-08-2006, 03:10 PM   #9
sport10's Avatar
This is the cheapest I could find at towerhobbies:
http://www2.towerhobbies.com/cgi-bin...I=LC4635**&P=1
Associated B44
Associated B6
Associated TC7.1
Old 03-08-2006, 05:06 PM   #10
UMMMM------ $42.99 http://www2.towerhobbies.com/cgi-bin...I=LXXB01**&P=0
or
$29.99 http://www2.towerhobbies.com/cgi-bin...?&I=LXJTE7&P=0
Old 03-08-2006, 06:18 PM   #11
sport10's Avatar
There you go. $29.99 is pretty cheap.
Associated B44
Associated B6
Associated TC7.1
You wont believe this KerryG Electric Off-Road 8 02-01-2009 12:04 PM
M11 wont return to center??? jla8874 Radio and Electronics 9 06-10-2008 01:12 PM
fast charging transmitter pack whilst still in transmitter Xrayskid Electric On-Road 2 02-06-2006 04:16 PM
NEED HELP! engine wont turn after reaching top dead center even without glow plugs!! tiger266 Onroad Nitro Engine Zone 12 09-24-2005 12:13 PM
transmitter that wont spring back corvettecrazy Rookie Zone 9 05-15-2004 11:45 PM
